Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile DElight keeps flashing. Freezer side OK Ref. side 58 Deg?????
    Champion:
  • 210 Answers
DONT KNOW?
Posted on Jul 22, 2008
My refrigerator/freezer is warm
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
Apr 28, 2017 | GE Profile PSW26P Stainless Steel Side by...
My refrigerator is getting too cold and freezing the products inside. I've lowered the temperature to 3 but it is still freezing. The water in the door is also not dispensing.
yes try the other knob make freezer colder it will make ref warmer.. what that knob does is lessen or makes more cold air come from freezer. less cold air should warm ref up. ok try that. later gator
Feb 18, 2011 | GE Profile PSW26P Stainless Steel Side by...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker not making ice
ck the tempt in freezer side should be 15 deg or lower to 0 deg . . adjust tempt control first / clean coils in back /and make sure both fans are going .. mm
Dec 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrigerator works intermitently
change the thermostat my dads fridge did the same
Aug 11, 2009 | GE Refrigerators
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 02, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
