Question about Acer Aspire 5100 Notebook
PXE-E61 Media Test Failure
I am getting this error, have checked the HD connection and everything is tight. After resetting the boot order to the default (HD, DVD, then Network) I still get this error. The odd thing here is that when selecting the boot order my HD and DVD models don't show up. They are represented by IDE-0 and IDE-1. After 10 or 15 reboot attempts the drives actually showed up and the models were listed in BIOS. The system booted up great and I thought that I solved the problem. Later in the evening I needed to install a Vista update which required a reboot and it started back up ok. Then, after closing the lid on the laptop, we get the same error again.
It makes sense to assume that the drives are ok but just aren't being recognized when booting up. Let me know if you could help me out.
Thanks.
  • JimLea Jul 02, 2008
    Also, My HD was recently replaced and I occasionally hear something moving around in the computer. I sounds like a piece of plastic is loose and is either hitting one of the fans or a piece of the fan broke off. Not sure if this could of caused something to loosen up on the board and I have read of another person having the same issue with the error and a rattle sound. Perhaps this is just a coincidence.
    Sergeant:
    Champion:
  • 244 Answers
When you get that error message, it's mean that your laptop isnot detecting your hdd, that's why it try to boot from network. Since you said you replaced hdd recently,
I believe your motherboard is bad.
About the fan, you can open the back door,
you just need to open the door and you can see the cpu fan.
Posted on Jul 04, 2008
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
When I start my computer I get the message PXE E61 Media Test Failure:check cable. Please, help me.
Make sure first boot device is NOT set to network in the bios or maybe the hdd has gone and its looking for a operatin system to load Check cable connections (reseat),
Check jumpers on hard drive for Master/Slave or CS settings,
Check BIOS settings for boot order,
And lastly have your BIOS rescan your HD or reset your BIOS to defaults.
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Aug 18, 2011 | Computers & Internet
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Error pxe-e61 media test failure
download new drivers for it, it can be registry error run registry cleaner reg in out may solve the problem
Sep 15, 2010 | HP Pavilion dv1000 Notebook
PXE-E61 Media test failure
See this on-line thread from other users. I'd be leary about the posts that advocated hitting the laptop...
http://www.nocrash.com/ncbbs/msgs/3247.shtml
Portable computers can suffer from bad connections easily, so the first thing you should check are that all cables and other connections are tight and seated firmly.
Mar 31, 2010 | Acer TravelMate 2300 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Try resetting the BIOS to the default settings and reboot
Nov 28, 2009 | Compaq Armada E500 Notebook
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
Aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Sep 28, 2009 | Acer Computers & Internet
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Acer Aspire 5100 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
