Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Allen screw B&D spacemaker ODC325
Sorry to bother you but the allen screw on the back of the ODC 325 is tamper proof, where do I find one that fits and do you know what size it is? My coffee maker won't transfer/heat the water and send it to the basket. Do you think I need the entire heating element or just the thermostat and fuse? (that's if I can get the screws out) thank you!
  • plhorner Sep 29, 2008
    My coffee maker starts to send the water to the basket but then stops. And often it doesn't send any. This coffee maker is approximately 8 years old and is built into a cabinet in our tour bus, so I can't readily just replace it with another.
    I would like to remove the tamper-proof screw to see if I can figure out why this is happening and hopefully repair it.
By sticking a small screwdriver where the pin is inside the torx type fastener, I was able to break the pin. Then a torx 10 or 15 will easily unscrew the screw. Maybe an allen wrench would as well, if it would fit.
A rather costly 35 dollars or so (plus shipping) heating element incl thermostat is available, if indeed that is the problem. You might as well find someone selling a used unit on ebay, after paying that much.
Posted on Aug 04, 2008
I can't remove the backplate off my Neff B1421 oven
its a tamper proof screw at torx 20 size.dont undo with a phillips tool will ruin the heads and never get them out.
Mar 05, 2014 | Neff B1421 Electric Single Oven
I have a spacemaker that leeks at resover
Used/Cannibaliized Replacement parts for ODC 325 B&D Spacemaker Coffee Makers are regularly sold on eBay, including the entire water reservoir or even the water valve in bottom of the reservoir (the leaky old one can be pushed out from the inside of the reservoir, and a non-leaking used replacement valve can be pressed in in its place).I sometimes buy an old broken ODC 325 cheaply on eBay as a source of parts.
Dec 30, 2013 | Black & Decker SpaceMaker ODC325 Coffee...
I need bracket
There's one on sale on eBay right now. Just search eBay under ODC 325.
Dec 23, 2013 | Black & Decker SpaceMaker ODC325 Coffee...
Prssure washer m1000 3 hp used to wash boat water leaks from inside cannot find allen wrench to fit wrench has small hole in center
They are probably not allen head screws but rather tamper proof Torx screws. You can break out the small pin or you can now buy special Torx bits with holes to remove tamper proof screws. They should be available at most hardware outlets or at shops that sell Chinese imports. Torx bits are prefixed with a "T" and the size you are looking for is probably about a T20, but the sets come with an assortment of sizes up to about T40.
Apr 22, 2011 | McCulloch FHH18A Electric Pressure Washer
Odc 400 dont work
Need a few more details. When it's plugged in: I assume it doesn't brew; Does the clock work? Does the base element warm up when the switch is moved to on?
Jun 29, 2009 | Black & Decker SpaceMaker ODC325 Coffee...
Water resevoir leaking
Replacement ODC 325 water reservoirs no longer for sale.
I keep a second ODC 325 machine for canibalization. The black rubber water valve assambly can be repaired (I did it 2 weeks ago) but it takes some creativity.
Nov 10, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Screwdriver
it is probably a "tamper-proof' Torx head screw and you will need to get a set of tamper-proof Torx bits. Be certain the tamper-proof Torx bit will fit into a bit holder shaft ssmall enough in diameter to fit into any recessed holes that the screws are currently in.
Jul 30, 2008 | Rowenta Steam Generator DG050 Iron
Abtec and coffee maker parts
I agree that abtec isn't cheap when it comes to shipping costs, but they're the only company I've found that even offers repair parts for the ODC325. If you don't want to buy just the thermostat, the entire heating element + thermostat is available as well, in which case you just unplug the old unit and plug in the new unit. Soldering the thermostat isn't that hard if you're handy with a soldering iron.
Jun 23, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Black & Decker ODC325
Small allen screw at the back of the unit next to the power cord entry. Gently work the two halves of the unit until they separate.
Feb 27, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
166 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
