This could be a hardware problem, but likely it is a driver or default configuration problem.
If this printer is hooked up to the network and you print to it through a print server, the default print setup or driver could be incorrect or misconfigured.
Whether it is hooked to a network or not, check to be sure the driver is correct under the printer's properties.
Also check to see if it's default settings are set for it to print only in black and white. Both can be done through the printer's properites.
check in the printer properties and make sure on the color page that "print in grayscale" is not selected. This option will make the prints all in black (grayscale)....
You can replace by color. Keep in mind if one color is out, it may not print.
You might be able to get around it by selecting black and white printing in the printer settings under the control panel. It's in the advanced settings of the printer.
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
No such printer. 5110cn, 5100cn, 3100cn, 3110cn etc.
Their biggest color laser that they have currently is the 5110cn.
5210n, and 5310n are B&W printers.
But all manuals for Dell printers can be found on the Dell site.
Just do a search on the model.
Or you can do a search by service tag (service tag can be found on a little white sticker where you put the tomer in).
