Im getting an error code 08-0E89-0000 how do i fix this I had Toshiba A305-6844 after removing all the partition from the HDD using Recovery Disk I get Error #08-0E89-0000 while recreating the partitions on the Disk and Install Windows Vista. Can any one help me to recover my HDD. Thanks! Rajesh Kanchan
I had the same message, replaced the hard drive, still got the same error code, took the hard drive back to best buy and they game me a new one, put it in and got the same message again...
Posted on Aug 17, 2009
    Genius:
  • 2,028 Answers
Getting this error during the set up process indicates a hard drive failure, usually a bad sector. A bad sector will not stop the hard drive from trying to load, it will however keep the drive from working properly. Generally it will load and then be unable to read from the bad sector, creating a problem booting, system glitch, or blue screen error. You will have to replace the hard drive.
Posted on Jul 02, 2008
I keep getting a error F3-F100-0004 on my Toshiba lap top L455D-S5976 ....f8,f1, & 0 won't work how can I troubleshoot to fix this error & can I do this without using CD or USB
Hi
If you would power up the unit for the first time then you will see that the Win 7 has been already preinstalled and it's ONLY need to finish the setup process...
This will take some time... however... after the Win 7 installation you can find an preinstalled user manual... most people don't read this and this is a big mistake...
In user manual you can find all the details which you have mention here in the posting
> 1) There is no DVD media with Windows 7 recovery.
There is an HDD recovery option available which allows you to recover the unit without the recovery disk... but you can also create an own recovery disk using the preinstalled tool called Toshiba recovery disk creator!
> 2) During the install process you MUST follow all standard options (no extra partitions) if you want to be able to use the recovery partition on the hard drive every again.
As far as I know Toshiba preinstalled Win 7 is an image and does not allow to change the partitions... you can change this only if you use the Microsoft Win 7 disk and this should be clear...
However, the recovery disk should be created ALWAYS as because there is always an risk that something would go wrong with an HDD or partition...
With reocvery disk you are always on the safe side
May 06, 2017 | Toshiba Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Hard disk error code 2000-0146
If happens that's the message it gives you by the machine, most likely its already a hardware problem but if you want to make sure try to do HDD scan, you can just go to any computer local center have them check if the HDD failed and if it failed you can purchase a new one.
Apr 21, 2011 | Computers & Internet
Hi i need to restore my Toshiba A100 - TA2 Model # PSAA8C - TA202C i had a virus on it and it crashed my computer before i could get it fixed... Please email me back on how i can fix my computer myself...
Using the Toshiba HDD Recovery Utility from the recovery partition
In the event of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in the special partition on the hard disk drive).
You can elect to restore the entire hard disk drive to the factory default state, or to restore only the C: drive -- without affecting other partitions (for example, a D: drive) -- or to change the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computer's HDD, follow the steps on this link:
http://tinyurl.com/4jkfsek
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 17, 2011 | Computers & Internet
What is the error code during recovering
That is either a currupt partition or bad sectors on your hdd.
You will need to run the recovery media and see if you still get error messages to know if it is a failing hdd.
May 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do i reset the m305-s4910 to factory setting
Recovery
  • How to recover a Toshiba notebook with the HDD recovery procedure
  • http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
From CD
  • http://cdgenp01.csd.toshiba.com/content/support/downloads/PMA500339010_web.pdf
You may have a hidden partition on the harddrive - if so you can recovery from there - BUT - you should also be able to create some bootable recovery DVD or CDs from the hidden partition using the toshiba recover cd creator Two ways to get to the hidden partition on Toshiba
  • Press an hold the zero key and power on - this will enable the recovery menu
OR on later models
  • Tap F8 as it boots and then use repair computer - from menu
  • How to recover a Toshiba notebook with the HDD recovery procedure http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
if not you can order replacement recovery cds
  • https://backupmedia.toshiba.eu/landing.aspx
Apr 10, 2010 | Toshiba Satellite M305-S4826 Laptop
System Recovery Media error 10-FA11-045D
This error comes up if the toshiba recovery cannot recognise the file system and partitions. try removing all partitions using the fdisk utility or a windows XP CD and then run the recovery.
Mar 09, 2009 | Computers & Internet
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
CHANGED HDD FORMAT
The best thing you can do now will be to obtain a windows Startup disk and use fdisk utility to format.. If you are using a seagate HDD then you can also try seagate disk manager. Another option will be to boot from win XP CD and start the setup.. During the setup it will at some point it will provide you the options
1)format using NTFS
2)FOrmat using FAT
3)Format Using FAT32
From these choose format using FAT32. Thats all it will be formatted.. Afterwards you can use a tool like Partition Magic to resize and create more drives on the HDD.
Sai.
Mar 21, 2008 | Toshiba Satellite P105-S6104 Notebook
Recovery Error
Any devices connected to USB ports?
Oct 09, 2007 | Computers & Internet
Computers & Internet Logo
1,543 people viewed this question
David Payne
David Payne
