I was using the camera and it just froze, and now the display screen and red light are flashing and it wont turn off. How do I stop this or reset the camera?
Comments:
Jul 03, 2008
- I have change your rating sorry.
I have change batterys, I have change the sd card, I left it of for quite a while but stil nothing help. Please let me know what next.
-   This is a new camera in box. I just wanted to see its functioning for selling it to a costumer.But it keeps bliking the red light and LCD and it wont turn off! What a Shame for HP!-   solaris2020
Apr 30, 2009
-   Red light and LCD display flash incessantly when batteries inserted. Cannot be turned off.
-   Guest
Apr 25, 2009
-   After inserting the batteries the LCD screen flashes bright and the red power button blinks.
I've tried the battery and card solution. Not sure I know how to do the firmware update.-   HPchallanged
Oct 26, 2008
-   HP Photosmart camera will not turn off. Timer red light flashes continually and the lcd screen blinks continuously. Tried the docking station to down pictures which it did but no affect on problem. Only taking batteries out stops camera from being on and blinking-   rehorton63
Remove the batteries and SD card for about 5 minutes. Reinsert and see if that resolves the issue..
Comments:
Jul 03, 2008
- Why an inappropriate rating? That is a negative rating and only reserved for solutions that have absolutely nothing to do with the query. If the solution provided didnt help, please post back, as it is not always possible to resolve an issue in the first instance itself. Please post back with steps you have taken, and i will be more than happy to assist you further.
I request you to change the rating to at least a Helpful, please.
Jul 03, 2008
- Thank you for that.
Like I posted in another thread you sent me, you could try updating the firmware. Go to the HP website, locate the firmware for your camera, download it to your PC and follow the instructions to reload it into your camera. Should even that fail, then I'm afraid there is a problem with the circuitry, and you will have to get the unit servicd, or purchase a new one, whichever works out cheapest for you..
This camera needs quite a lot of power from batteries on power-up. When it gets older, the grease disappears from the bearings and motors are harder to turn - so motors need even more current. This makes battery voltage to fall too low an camera resets. On reset blinks front red LED and a LCD. This loop can take as long as there is some energy in batteries.
I solved this by connecting the camera to the external power supply (6V, 2A). It boots normaly.
The next step I will make is to disassemble the camera, put some fine grease for fine mechanical parts in every bearing and slide. It should help.
The other solution to test is to mount a small resistor (I guess about 1 to 10 ohms) in series with the motors. This will lower the power-up current. But also all movements will be a bit slower.
i changed my base unit yesterday and haven't been able to install my printer (hp photosmart c5280...
(More)
I CHANGED MY BASE UNIT YESTERDAY AND HAVEN'T BEEN ABLE TO INSTALL MY PRINTER (HP PHOTOSMART C5280 ALL IN 1 PRINTER) AS I HAVE LOST THE DISK
We have a HP 945 and the on/off tab have broken off. Can this be fixed? also interested in replacing...
(More)
We have a HP 945 and the on/off tab have broken off. Can this be fixed? also interested in replacing or repairing the display screen, it is scratched - this is not a necesary repair, just wanted a general idea of cost to replace the display. however the On/Off switch will have to be fixed, if possible
my 945 is starting to mess about by putting lines across the dispay of our takn photo, I doesnt do...
(More)
my 945 is starting to mess about by putting lines across the dispay of our takn photo, I doesnt do it all the time but is becoming more often - any ideas ?
keeps turning itself off, won't take a picture - just freezes. Then, after manually turning the...
(More)
keeps turning itself off, won't take a picture - just freezes. Then, after manually turning the camera on, it will sometimes take a picture. New batteries in it as well
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
