Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover SteamVac Widepath F6023-900
Wife was using it ,she said it started to smoke
BOUGHT A NEW ONE
Posted on Jul 03, 2008
Attach the hose to a "hoover f7425 900 steamvac v2 widepath
click here> http://hoover.com/file/670/ for the manual it will give you full instructions how to attach the hose
Sep 25, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Steamvac f7452-900 carbon brushes
are you shore it's not the turbine that you have a problem with
Oct 30, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover F7458-900 steamVac all terain. I
You can reach under the brush (on top) and pull down. The manual for an all terrain is here to download
F7452900
Apr 10, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover SteamVac F6030-900. Does not **** up
check the black plastic motor cover. these frequently melt and loose seal due to the extreme heat of the motor. if the plastic is warped, then that is the problem. also check for hair and cloggs throughout the suction ports
Feb 26, 2010 | Hoover F6030-900 SteamVac WidePath Wet/Dry...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Need directions
This is an older model Steam Cleaner. The upper tank, fill with hot tap water up to the fill line, then add 5 ounces of carpet solution to the water using the upper cap to measure. Make sure the lower letank is secured and turn it on, tilt the handle back, pull trigger to release solution to floor going forward, then release when pulling back slowly to extract. I am not sure if the manuals are available online, however you may be able to locate a Hoover dealer which may have a digital copy. They can be found through the hoover.com
Jan 19, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover widepath steamvac
One cause is the filter in the dirty water tank lid is pushed up too high, it needs to have a gap of 1/4 in or so. So check it, if it is up all the way, pull it down some.
Jan 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
448 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
