Question about Canon PIXMA MX310 All-In-One Printer
MX 310 paper jam
I have a paper jam prompt that won't clear. I don't see any paper inside the machine.
  • 10 more comments
  • lorenalexis Oct 04, 2008
    I have the exact same problem. Anybody have a solution?
  • Anonymous Oct 19, 2008
    same thing and I am pissed
  • timpylka Oct 25, 2008
    States I have a paper jam, no paper found to be 'jammed' anywhere! If I turn-off and unplug the machne, it will reset so I am able to make one copy before it displays that I again have a 'paper jam'.
  • tommie123 Oct 26, 2008
    I have the same problem, have you got the solution????
  • Anonymous Oct 27, 2008
    exactly the same paperjam wont clear
  • Anonymous Oct 28, 2008
    Me too! There says there is a paper jam, but there is definitely no paper in the printer.
  • Stian Nov 07, 2008
    Same thing here, had one paper jammed, took it out by pulling it out from the top (which was the only way to get it out) and now it says I have a paper jam, when there is absolutely no paper in the printer whatsoever. The paper I took out came out in one piece, so nothing is left in the printer..
  • Anonymous Nov 12, 2008
    Same problem here.
    This is obviously a flaw.
    Any solutions?
  • babsieko Nov 23, 2008
    I have the same problem. No paper can be seen anywhere and the printer continues to say Paper jammed. I have tried to reset, turned it off and on, left it alone and off for awhile, bit it continues to say paper jammed. What to do?
  • Anonymous Dec 02, 2008
    same problem!!
  • Anonymous Dec 07, 2008
    I still have paper stuck in there somewhere and wanted to know how to get it out when you DO have a paper jam :( It just says "Check printer" and wont do anything.
  • jcarithers42 Dec 30, 2008
    same problem exactly.
Posted on Oct 21, 2008
I have a sharp 2700 copier with code H5-01
H5-01 means you have had five consecutive jams, it would suggest there is either something blocking the paper path, or the paper is not being picked up at all.
Try resetting the machine by the following:
Program, *, clear, *
It will then ask for a simulation code, enter 14 and press print, are you sure?, press yes. Clear all, clear all, should reboot the machine and try again.
If it continues to jam, try a different cassette.
Apr 23, 2015 | Sharp MX-2700N Color Copier
How do I fix a paper jam?
You said it is not used often. If there has been a paper jam and you removed the jammed paper sometimes it helps to unplug the device to clear the error conditions. Another possible problem is a tiny peace of debris still inside the machine blocking a switch or other sensor. If there has never been a jam it still could have some bit of foreign material down in the machine. These are the most likely causes
Sep 29, 2014 | Olympus Camedia P-440 Digital Photo...
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Hi my canon mx 310 is jamming all the papers sent through it goes in ok and once it hits the wheel that turns the paper it is pushing it to the right and ripping the paper
check for paper residue at the right roller...then...
.The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Jul 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon laser base mf3220 problam error signal 225. plase send the solition. mahmudboe
Error 225 means there is a paper jam. It could be small piece of paper. Therefore, I suggest that you carefully inspect the inside of the machine to locate the paper. Check and make sure that the paper path is clear from input paper trays to output trays.
Let me know if any further clarification is required. Hope this helps!
Nov 26, 2010 | Sharp MX-3501N All-In-One Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
MX 310 says no paper.
try wiping off the rollers that grab the paper. sometimes the get dusty and can cause that malfunction.
Mar 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Canon MX 310 printer says it has a paper jam. I found one and cleared the but can't find any more. But, I can't clear the printer so it keeps giving me the same message and won't print.
Try this. turn off the printer and unplug it
open the paper jam door and give the paper roller a gentle roll upward (forward) until you hear a click. reclose the door. Leave the printer unplugged for a few minutes.Plug your printer back in and restart it.
I hope this works for you. If not let me know!
Aug 17, 2008 | Canon Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
542 people viewed this question
old marine
old marine
