Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Panafax UF580 Is it possible to limit the transmission rates the machine advertises. The device is using V.17 with another fax machine but constantly recieves error 407 which after a google is an indication that the far end didn't send MCF which in turn indicates more than 5% of lines were errored. Can I force it to use V.29 through the configuration
    Genius:
  • 2,120 Answers
Not recommended, it just screws everthing else up.
Posted on Aug 30, 2008
I'm getting error code 388 when I fax to one specific location - can fax to all other numbers but this one.
The fax machine has originated a fax session and detected a remote fax machine but has been unable to connect to it. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode it is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
or
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. I hope I have been able to help you. Have a NICE Day!!
Jan 26, 2011 | HP 1240 Plain Paper Inkjet Fax
Error 388 when trying to send a fax
The local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Dec 17, 2010 | HP Photosmart C7250 All-In-One Thermal...
This isn't limited to Brother, but we have a customer who is claiming their fax machine was "brought down" by one of our transmissions to their fax machine. The repair person told them they...
I only have 27 years in the office equipment service business but I can tell you that I have never heard of such a thing. Also my back ground in Electronics tells me that it is impossible to damage a circuit board using a digital transmission over a phone line. Could the phone line itself cause it? Possibly, but certainly not your fax transmission itself.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Brother Office Equipment & Supplies
Change baud rate on panafax uf880,885
That won't make any difference. ALL fax machines are ANALOG and won't work on a DIGITAL phone lines reliably
Nov 17, 2009 | Office Equipment & Supplies
I bought a panafax-uf790 about 2 years ago. Now I am having the worst paper jam problem. It would always stop at the same place and record paper jam. I've constantly remove the paper and it keeps giving me...
Just a suggestion, Try the following, obtain a compressed air canister, or a compressor filled with air, open the unit from where the paper feeds and ejects after printing, blow the compressed air through the feeder and the ejection side, turn the rollers if possible whilst doing this.
May 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Telephone rings only twice
No. Fax machines are designed to have their own dedicated fax lines.
Some newer models, tho, allow you to set NUMBER OF RINGS.
Oct 30, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
PANAFAX UF-6000
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
I have my husband's Panafax UF 895 fax which I am using since my other fax broke. We set it up, but he can't find the manual -- I can fax out and copy, but can't receive faxes. On the display it says...
Your machine is set to Manual Receive.
You need to change Function 17 to 2.
Go to Fax Parameters on the below link to help guide you through programming the fax parameters.
Basically, you hit FUNCTION, then #7, Press #4 and Set,Enter 17, hit Set, enter 2, Set. After you are done, then press STOP, and your machine should be set to AUTO RECEIVE.
Here is a link for the user manual:
http://www.best4systems.co.uk/_design/best4systems/_pdf/Faxes/Panasonic/Panasonic_UF885_UF895_UG.pdf
You should probably save a copy of the manual on your computer incase the link is lost or shut down in the future.
I hope this helped.
If you have more questions, please repost again and remember to leave a rating if I have helped you.
Good luck.
Mac =)
May 02, 2008 | Office Equipment & Supplies
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
194 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
