Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Our freezer works fine ....but our frige isnt ..help!!!!!!!!!!
Yeah our freezer is still cold but the other side isnt
  • jimaxsom Jul 05, 2008
    We unplug it and let defrost and then the fridge side will cool down to 40 but eventually will warm back up to 55
  • 828 Answers
Your automatic defrost system is not working. There is a timer which controls the defrost by turning on the heaters for 18-22 minutes inside the back wall of the freezer section. after the defrost time it returns the system to cooling.
You have one of three items faulty. The timer, the heater or the defrost terminator switch.
Posted on Jul 07, 2008
The freezer works fine, but the frige side is not cold at all. the unit is still under warranty, and the service guy replaced the "control board". but that worked for about a week. Everything is...
Hello Patrickbono,
I understand that your are having a problem with your fridge it is not getting cold. However, the freezer is cooling just fine this is a common occurrence when the evaporator fan goes out in the unit. Here is a tip you can follow to help you diagnosis the problem
Fridge not getting cold?
I would suggest you call the service tech as the unit is still under warranty and have them to replace the fan and check the rest of the unit.
Thank you for choosing FixYa.com
justinbur167
May 11, 2011 | Samsung RS265LBBP Side by Side...
Refrigerator isnt cold anymore but is running
Sounds like a too low setting or the compressor shut down.
Dec 01, 2009 | Cars & Trucks
Freezer works fine but frige side not getting cold enough-side by side unit
Check rear wall of freezer to see if you can feel frost about halfway down. If so you likely have a defrost system problem. Three components involved in defrost system, Heater, defrost thermostat and defrost timer or Defrost control (circuit board).
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model and brand is always helpful when requesting information.
Aug 22, 2009 | Kenmore Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
