Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
2 Wire Won't reconize network
My 2 wire works great at home and am using Belkin wireless router. But at my church it will not even recongize the wireless in the church and I am right next to the router which is also a Belkin. What is wrong?
  • 3 more comments
  • dalewaite Jul 02, 2008
    I was told to check if my drivers are up to date and I did that and they are but my 2wire will still reconnize the wireless network in our church
    That's not it either, as I had the local computer store that repairs are computers at church look at that and could find nothing wrong with the configuation on the router at church. Would having the disks that came with 2wire solve my problem. I no longer have the disk as I got the computer 2nd hand. How would I get a copy of the installation disk?
    I changed it to windows searching for wireless connections but it did not find any network. Next help please
  • signs4fun Feb 13, 2009
    I have the same problem. The 2wire adapter was connected to a Qwest modem. I bought a Belkin router and the 2wire couldn't find the modem. It was able to see six others in the neighborhood. I have a wireless laptop that will connect to the Belkin router. I have the software that came with quest and tried to change the installation where asked for the last three numbers of the serial number and the ten digit code. It would only accept the ones needed to connect to the quest router M1000.
    I still haven't found a solution. I've called 2wire and Belkin.
    Sorry, Let me know if you find a solution.
    Don
  • dalewaite Mar 19, 2009
    I finally found the answer at least for me. I purchased a program from www.purenetworks.com called Network Magic. It cost basically $30.00 was easy to install and took care of all of my network problems and now if someone comes over and logs onto my network it will show right up on the program screen who is logged on and what software they are using.
  • 405 Answers
Are you using 2-wire's software to search for the wireless newtwork? If you are try switching it to the windows wireless newtwork utility, and vice versa.
Posted on Jul 02, 2008
  • Patrick McGee
    Patrick McGee Jul 02, 2008
    Can you provide the model # of the belkin router at the church? I can try walking you through the process of making sure it is broadcasting it's identity. If it is broadcasting then we know it's a problem with your card, if it is not broadcasting all you have to do is set it to broadcast and you should be all set.
  • 86 Answers
It sounds like the administrator for your church's network has turned off SSID broadcasting in the router as a security feature. You would need to contact them to find out the network SSID and then enter it manually into your wireless client software. The other option is to ask them to turn the SSID broadcast back on temporarily so that you can connect.
Posted on Mar 19, 2009
    Sergeant:
    Champion:
  • 248 Answers
The problem may lie in the church's router... can other wireless devices see the church's router being broadcasted? if not then there is an option in the router that will turn broadcasting on...
If other devices can see the router's wireless broadcast and only your 2wire cant see the router then it may lie in the 2wire's software... or windows, try restarting the wireless zero service in your control panel > administrative tools > services" restart wireless zero here and try to use windows' search again...
you can also configure your 2wire to specifically connect to the router in your church but you need to do this manually by putting the ssid and wep keys when creating a new wireless connection...
  • 689 Answers
Hi
It seems issue has a simple cause, Most likely Hidden SSID has been assigned at router side or Wireless Mac filtering, But since you have confirmed your 2wire network card works great, we should check the your wireless settings at Router. You can access router with already connected computer by typing 192.168.2.1 (it can be different as you can see on gateway info). Please let me know the outcome. If you are unable to resolve we can still discuss it further here or on the phone. Good Luck
  • 2,071 Answers
First find the chipset for your wireless card;.
Open a terminal by clicking on application /accessories/terminal, then for a PCI wireless device enter:
Code;
1spci
or for a usb device enter:
Code:
1susb
if your card is pci then look under network controller , then if a usb card will give a pciid which you can use info,to search to google...
  • LORETO LACARON
    LORETO LACARON Jul 02, 2008
    Another option be sure you get the WEP key entered correctly.One important thing to check your local area connection and make sure it will automatically obtain and IP address. Just go to control panel>network connections,right click "local area connection"and go to properties . Highlight the "internet protocol" entry in that box, and click properties.Verify that both IP and DNS are set to obtain automatically .If that's set and you have your WEP key in correctly, it should work......
  • LORETO LACARON
    I found a site 2wire more information and drivers
    http://www.ubuntu-unleashed.com/2008/02/...
    80211g-wireless-usb.html
    Master:
  • 848 Answers
Try to reset it .You can always reset the router to factory default settings. Keep in mind you WILL LOSE any changes you have made (whether it be wireless configurations, port forwarding settings, etc). But, if that doesn't matter to you, resetting it will allow you to start from scratch. You must know what your Internet settings should be: whether dynamic IP, static IP, or PPPoE so you can get back online.
note the passphrase you can change that if you log into your router and adjust the wireless settings. You would need to do this from a machine that is already has connectivity or hard wire the laptop to the router. To do this type 192.168.2.1 into the address bar in Internet Explorer of a connected machine. If you have never adjusted this, the password should be blank and you can just proceed.
Navigate over to wireless settings and the security setting and change the passphrase to whatever you want. If there were any wireless computers working on the network previously then you will need to update the passphrase on them to reconnect.
To actually reset the router, there should be a small pinhole button labeled "reset" which you will need to depress for at least 30 seconds, probably more.
    Brigadier General:
  • 3,614 Answers
It need to be re-configure on the router on your church..
  • 2,794 Answers
Go to 2wire.com and make sure your drivers are up to date.
I have a belkin -n1 wireless router.. it is a great router because it works all the way through the house. the only problem with it is that i cant update my xbox with it, neither by wire or wirless. if it...
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 09, 2010 | Microsoft Wireless Network Adapter Xbox...
Laptop stopped connecting via wifi to home network.
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 31, 2009 | Belkin (F5D7231-4) Wireless Router
Wireless connection
On your computer, click "view available networks".
Click to select the SSID that you created for your router.
Click CONNECT.
Nov 06, 2009 | Belkin (F5D7231-4) Wireless Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Wireless with no cable to wireless laptop
this is just the first setup step for you to access the router interface page to setup your wireless network name or SSID, encryption type, encryption key, etc ....
Jul 04, 2008 | Computers & Internet
Using 2 routers
You may use your wireless router as an Access Point:
1. Connect one of the LAN port of the Belkin to a LAN port on your Voyager. If the link light on both side are not coming on, try using a cross-over cable. Important: Do not connect anything to the WAN port of your Belkin.
2. Configure the LAN IP address of your Belkin in the same subnet as the Voyager. By example, if your Voyager has 192.168.0.1, you may give your Belkin 192.168.0.3.
3. Disable the DHCP server on the Belkin since the Voyager most likely already has one.
4. Configure the Wireless parameter of your Belkin as you would normaly do.
Using this method, your wired and wireless devices will be able to communicate together since they will be on the same network and your Belkin will act as a bridge between the wired and wireless network.
Apr 20, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin n router.
change the wire less channels use 1 or 11>and always keep teh wire less pc close to teh router>and disable the fire wall in the router rate me solved if its helps thx
Nov 15, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin wireless
What wireless card is located in the computer that will not connect? What model Belkin router?
Oct 03, 2007 | Computers & Internet
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
537 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
