UNKNOWN VALUE OF VOLTAGE ZENER DIODES
THERE ARE TWO DEFECTIVE COLOR CODED BUT I DONT KNOW ITS VOLTAGE VALUE,THEY ARE=RED RED BLUE AND W/BLUE BAND ON ITS LEAD
  • mcbdalisay Aug 23, 2008
    there are two defective zener diode in the power supply section of the panasonic tv model:TC-21F3P.one is a stripe yellow zener diode and second is stripe gray zener diode.i dont know the value and the voltage. any suggestion?pls
  • Jaime Hernandez May 11, 2010
    Could you provide the model number of your TV?
    I could try to find the service manual.
  • 2,334 Answers
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Posted on Jul 02, 2008
6,2 V zener dioda red,red,blue
Posted on Sep 23, 2009
It is the national/panasonic color tv,model # TC-21F3P
please give me the exact value of this voltage zener diode. red red blue and a blue band labelled on one of it`s lead.thanks
What the voltage value of zener diodes? (D825, D826 red,red,gray) and D823 (red,yellow).
This table is the information used by MOST diode manufacturers that use color banding on diodes. Most manufacturers stamp the ID right on the diode but some do use color banding as the method of identification. For purposes of alignment, the side with any color band closest to either side of the diode is the equivalent of the left side of this table. The three examples in the table when associated with the values in the lower table, are identified as 1N64E for the top diode, 1N452G for the middle diode and 1N4762 for the bottom diode.
See the color coding
25789975-o5icj23xic0ud0c1fg3qznri-3-0.jpg http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Panasonic Televison & Video
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
Color is all red
i dont know contact you service
Apr 08, 2011 | RCA F32645 32" TV
Burnt Zener diode... Voltage spec??
On the cathode of the zener diode look for a filter cap and check its value the voltage of the zener should be less than the working voltage of the zener. Basicly its likely being used as a shunt regulator as protection and regulation of the voltage. When the zener hits a certain threshold it will breakdown and start conducting to ground until the supply regulates and then it will recover. If the filter cap for that voltage rail was 25V I would guess that the zener would probably be regulating between 12 and 20 volts. I'd pick a 15V Zener its probably +- %10 on the original and any system should be able to take a %10 tolerance as a general design rule.
May 07, 2009 | Emerson Televison & Video
Ziener diode
Yes, Zener diodes can work both on forward and reverse biasing. The primary difference between a zener diode and the ordinary junction diode is it is designed specifically to operate with a reverse bias voltage that is high enough to cause the the device to breakdown and conduct a high reverse current. Hope this answers your question and provides you with some help. If you need further assistance please let me know.
If you do not mind, would you please rate my help. I would very much appreciate it. Thanks
Dec 08, 2008 | HP Pavilion dv6000z Notebook
Televison & Video Logo
1,291 people viewed this question
Top Televison & Video Experts
