I have a Raypak pool heater with a invensys gas valve, the burner is not kicking in, pilot light is lit and stays lit, I jumper the complete switch circuit and still does not kick in. this is a millivolt system, do I have power? is the gas valve repairable? thanks Mike
    Scholar:
  • 104 Answers
Usually not the gas valve unless line voltage was applied to it. Millivolt systems are very touchy about connections. First check the output of the millivolt generator (thermopile) the wires for this usually go straight to the gas valve they should be one red and one white usually in a high temp fiber glass sheath. The wires will lead from the gas valve to a rod by the pilot. Test between the two wires with a meter that can read mV DC. You should have somewhere in the neighborhood of 450-600mV DC. If you do not, then the thermopile is bad. If you do, then it is either a bad connection somewhere or an open safety in the circuit. Check all of the safety devices and clean all of the connections in the unit with sandpaper. Usually for safety devices there will be a high limit on the discharge of the header, a pressure switch sensing water pressure, and a rollout switch or two in the control compartment above the burner. Good luck, I have to battle with mV systems all the time at work, usually it's just a bad connection.
Thanks,
Chillmaster
Posted on Jul 03, 2008
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Pool heater pilot lit but burner is not lit
check safety circuit probably pressure switch or loose wires to gas valve
Jun 15, 2014 | Raypak Free Hydraulic Lift Gate Delivery -...
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Hi, I have a pentair minimax 250 pool heater and the burners will not stay lit. The pilot stays lit but burners will not kick in. I have it jumpered on the gas valve to heat the pool but I feel very...
first of all dont jumper the gas valve! if the pilot stayson and the burners wont fire there a a few reasons for that. one of your safeties are open.....malfunctioning potentiometer ( tstat control)......or theres a short or voltage drop through the circuit. ur pilot generator should have around 400 dc millivolts. if you follow the path in the circuit and anything drops to the 200dc mark then theres a problem. make sure ur electrical connectors are tight. millivolt models are garbage, as it takes very little to interupt the circuit
Jun 20, 2013 | Heating & Cooling
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
Pilot stays lit, but the burner will not light
You may need to replace the pilot assembly. Or maybe the gas valve.
Their two stages to the valve and the pilot generates two hundered milivolts (less than a quater of a volt) to open the pilot valve but it takes at least another three hundered or more to open the main half of the valve, You need to have a milivolt meter to check.
Jun 22, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have a Raypac C155A LP spa heater. won't light
I would agree with you. The pilot generator has probably degraded over the years and is only proving enough millivolts to power the pilot but not enough to run the gas valve for your main burners.
Replacing the pilot generator, preferably the entire pilot assembly, will fix the problem.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool heater won't stay lit
check gas pressure might be running out of pressure gas meter might be too small and heater could be overheating
Jun 03, 2009 | Teledyne Laars Pool & Spa
Heating & Cooling Logo
291 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
