Question about Brother MFC-8220 Fax
Printing Faxes All incoming faxes are being printed light. I changed the drum, changed the toner. Tried changing density, auto and dark contrast. How can I fix this to work better.
  • phillyr121 Jul 02, 2008
    Genius:
  • 2,120 Answers
Try another drum unit.
Posted on Oct 25, 2008
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
OKI 4550 fax
try to boot the front cover and clean the glass over the lens
Dec 29, 2008 | OKIFAX 4500 Plain Paper LED Fax
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Toner prints to dark
hi!!!!!
try to re-install the driver of your printer!!!
or try to figureout the settings of your printer
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Very poor print quality
the loud you hear indicate improper of mechanism of fax get drum unit out  and check for good condition of the unit (no broken in drum gear-or bad cleaning blade)-and reinstall it again- rip over toner box many times and check it  in horizontal level many times.if all above  does not work -you will have a problem in drum unit or your fax mechanism(broken gears-chain or belt defective-bad selonid-clutch-
Mar 12, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Lines printing out on faxes
white or black lines? what kind of machine? does it have lines when sending?
Nov 29, 2007 | Office Equipment & Supplies
Dark toner streaks
can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
Nov 21, 2007 | Brother IntelliFAX 4100 Laser Fax
Printing incoming faxes
Take out the drum and toner and look for dirt or toner on the filter glass inside the fax on the bottom.just under where the drum sits. also clean the drum charger with the blue clip on the drum unit. slide it back and fourth a few times. make sure you snap it back into its place. It also could be the toner cartridge or the drum itself. Lawrence
Sep 17, 2007 | Brother IntelliFAX 3750 Plain Paper Laser...
Brother MFC-8220 Fax Logo
153 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
