Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia LT 37 HVS HDMI PORT
I had a recent power outage during a thunder storm, the power was off only briefly(flickered off then back on). When the LCD came back on the color on the screen had changed from normal to a predominate black and red color with people figures still visible. This only happens when I turn on my LCD. To correct it, I must open the Menu screen and select the default setting to bring it back to normal again and then reset all my preferred setting again each time I turn on the LCD. My HDMI cable was the only connection from the LCD to the cable box. I have tried a new HDMI cable and had the cable company come and check out their equipment but the problem is still there. Any idea as to what could be the problem and how to fix it, thanks for your input. email: smoon472002@yahoo.com
  • jocabrasil Dec 09, 2008
    I have the same problem and I can not get it fixed.I bought this TV when I was living in US, but now I am in Brazil and the Olevia dealers here do not work wit this TV model.
    Someone can helpme indicating the part number I need to import in order to fix it??
Our Olevia LT37HVS 37 in. HDTV LCD Television is barely ever used when we turn the set on and the olevia light on front goes off but the set never comes on set this has been watched maybe 20 hours max
Posted on Feb 04, 2009
  • 975 Answers
You need to take the unit to an authorized repair shop to have it
check and correct it , looks like the power supply section got affected by the sudden change of voltage and damaged an internal part, hope this helps , AJ
Posted on Jul 02, 2008
HDMI Port Does Not Work
If 2 does not work it is likely the socket itself which means replacing the board they are mounted on, seen several techs try to replace a socket and not one had success.
Oct 14, 2012 | Olevia 237T 37 in. LCD TV
I have vizio sv470m and all of the 4 hdmi plugs stopped working one at a time.
Power doesn't have to be knocked out for a cable box to destroy the HDMI ports on a TV. Thunder miles away will put voltage spikes on the cable system which in turn trashes the main board in the TV. You can get parts for your TV here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 30, 2018 | Vizio VO47L 47 in. LCD TV
Only one (out of four total) HDMI input is working on my set.
The HDMI switcher IC chips in TVs can be damaged but lighting hits near you house even if the power is protected with a surge protector. The damaging power comes in through the HDMI port and blows the chip out and it can affect just one port or multiple HDMI ports. Your best bet would be to just get a cheap HDMI switcher and use the one working port. The repair on the TV would require placing the control board and would run from $75-150 for parts plus the labor to install it.
Aug 16, 2012 | Televison & Video
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Hdmi ports not working after thunder storm
Hi, During a lighting storm unplug or get a surge protector. Your too late to do anthing now. Go to a repairman. good luck.
Jun 29, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
We experienced a Sevrer Thunder Storm in our City on 07-23-2010 and as a result had a power outage for several hours. Once the power was restored, the Haier 3.5 cu ft chest freezer is no longer working and...
Hello
Due to the heavy storm you experienced,and since the freezer was plugged during that period there might have been a negative effect from the storm on your freezer due to earth.All you need to do is to get a technician to check it out.
THANK YOU
Jul 28, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Where can I buy a new power supply for a LV 37 HVS
if the plug you are look for looks like this read the bottom of the page to see where to buy it.
http://cgi.ebay.com/OLEVIA-LCD-TV-AC-REPLACEMENT-POWER-CABLE-CORD-3-Prong_W0QQitemZ320416963686QQcmdZViewItem
I hope this gets you going again.
Sep 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
587 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
