mornin. each time i attempt to use my dehumidifier, ice forms on the back where the coils are located. at that point, the unit continues to run and throw off heat. any thoughts?
Most dehumidifiers need warmer air to work properly. The temperature in a basement is usually 60 - 65F; too cool for standard models. You could buy a "basement" dehumidifier. They're designed to work at lower temperatures; some as low as 40 F. Costs are about the same as a standard dehumidifier; you just have to find it.
For a cheap fix, try this; it seems to be working for me.
Since the condensate coil (the one icing up) is cold, the air entering it is too cool and the condensate frosts up the coil. Additional condensate freezes to the frost and before you know it, you've got a block of ice. Since the air coming out of the front is very warm take a large piece of cardboard around 6' x 3') and form a V. Placed it in front of the dehumidifier so it channels some of the warm air back to the rear where it warms the moist air up before it hits the cooling fins. It's helped keep the ice down.
If you want something attractive, any screen that redirects some of the air back to the rear will work. Just leave the top open so it doesn't get too hot and the some of the drier air gets out into the room.
The fins and coil in the back of the dehumidified freeze up. Iused a brush and removed a lot of...
(More)
The fins and coil in the back of the dehumidified freeze up. Iused a brush and removed a lot of lint. The pan under this unit has a lot of lint and grit/
after 10 to 15 minutes of operation the coils begin to freeze at the bottom and progress to the...
(More)
after 10 to 15 minutes of operation the coils begin to freeze at the bottom and progress to the whole coil pack. I've cleaned the coils and the fan is operating properly. One expert suggested I change the humidistat which I did. 50.00 later and it still freezes up. If the coils are freezing how could low freon be a possibility? Could it be the thermostat? HELP yours truly Paul k.
I Just bought a dehumidifier and it did not come with instructions. Every time I turn it on the fan...
(More)
I Just bought a dehumidifier and it did not come with instructions. Every time I turn it on the fan shuts down after a couple of minutes. What could be the problem?
