Question about Samsung HP 4200 Laserjet Printer
The printer is printing the same thing multiple times on a page and the page has ink all over it in bands
  • 3 Answers
Check the transfer roller for impressions on it and also check the fuser to see if the protective coating is worn off.
Posted on Jul 02, 2008
HELP!!! Designjet T610 Prints Blank Pages. When printing multiple pages the printer start to print blank pages after the 1st or 2nd page. What can I do?
Go to Staples in your area or try the staples.com website you might be able to get the same kind of printer or better. the people at Staples are friendly and they will be able to assist you they know a lot about these kind of things such as printers, and computers, and tablets and stuff. See if they can help you better.
Jul 10, 2015 | HP Designjet T610 InkJet Printer
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
Why is there a clear horizontal line within the printed line?
The print-head is like a paint-brush, in that it prints a "band" as it goes across the page.
In your case, some of the ink-jets are CLOGGED, and thus are not shooting ink as the print-head moves HORIZONTALLY across the page.
Run a few "print-head-cleaning-cycles", to try to unclog those ink-jets.
May 14, 2011 | Canon BJ 200EX InkJet Printer
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
My system is setup for dye sublimation printing. it has been perfect for 2 years, but yesterday, I noticed banding in the dark, heavy ink areas. I first checked the nozzles (clean) but I noticed the...
Hi, I recommend getting a set of Epson ink, run through a few head cleans and repeat the head alignment a few times if required.
Sublimation ink is a lot thicker than normal ink, this means a typical dye based printer may struggle over time. Genuine ink contains anti coagulants which prevent the ink from drying and a cleaning solution within the ink. If this doesn't work you can try removing and soaking the print head in distilled water but I would only recommend this as a last resort and only if your confident in doing this.
Jan 28, 2010 | Epson Stylus 1400 InkJet Photo Printer
Band of ink on back of printed page
The exit rollers need to be cleaned, but whats happening is ink is coming from the bottom onto the rollers. It needs to come apart and be cleaned and a mylar strip put in to keep the ink from coming up. A shop repair usually.
Jul 14, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
Help!
Has it been a while since you've used the printer? If so, it's probably dried out a little. Try a couple things.
  1. Check if you are out of ink. The HP printer software will have an ink level picture indicating how much ink you have in the tanks.
  2. Print a test page.You can do this by click on the start menu, then selecting printers and faxes. Once you see your printer, right click it and choose properties. Then choose to print a test page. If that fails to print, go to step 2
  3. Clean the print heads. In the previous menu, you should find an advanced button. You'll have to search around a little as I don't have this printer, but there will be an option to clean the print heads. You may have to repeat the cleaning multiple times before you start to see an image.
If that doesn't work, comment back and we'll try some other things.
Steven
Sep 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp laserjet Printer
There may be a release lever for the print head assembly which would allow you to remove the print head and clean the excess ink from it. If it appears to get better the more pages you print it may be just a matter of time and lots of pages before it cleans itself.
Try running the print head cleaning utility multiple times to help reduce the amount of ink on the print head. This could take quite a few times before it gets better.
Mar 10, 2008 | HP LaserJet 2550Ln Printer
Dell A960 AOI Printer problem
Have you reset the ink levels for your printer? Some printer software refers to it as that others ask if you have installed a new cartridge.
Do maintenance on the printer, such as clean heads, print test page, head alingment, etc and see if that fixes it. You can get to all these options through properties
Sep 30, 2007 | Dell A960 All-In-One InkJet Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
