Question about Karcher 2500 PSI Pressure Washer
How do i connect the hose to the karcher k399 handle
Pop out the plastic tab at the base of your gun (use point of screwdriver/knife).
Then push the hose connection into the gun and push the plastic tab back into it's slot. This will hold the hose in place.
Posted on Jul 28, 2008
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
Can you suggest an alternative soft flexible hose for a Karcher power pressure washer 100bar
You need to ensure the Hose can handle the PRESSURE your machine is putting out. The Flexibility is a direct correlation to the requirement of the hose's ability to handle the pressure. Your 100 Bar is equal to 1460 psi. Depending on where you live, there are places that have Hose and Couplers and can make a Hose to your Specifications with the above information.
Mar 21, 2015 | Karcher Garden
Karcher 3.190 breaks hose coupling connector
use high quality brass fitting, low quality brass will break also,replace male and female side with matching brands
Mar 30, 2014 | Karcher Garden
Leaking handgun karcher k785
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. !!
Feb 19, 2012 | Garden
I have a Karcher 110 pressure washer and when switched on to jet wash the water is coming out of the handle and just trickling out of the jet nozzle please can you help. Thankyou Brian Hills
Which part of the handle is water leaking from? It could be that the hose connection into the gun is not fitted properly. Otherwise it could be that you just need to replace the handle.
Feb 28, 2011 | Garden
Karcher k2.360 modelonly one year old the hose connection to the handle trigger keeps shooting off
make sure that the pin (item 1) is secure when the hose is pushed up into the gun. johnson9999.jpg
Jan 15, 2011 | Garden
Faulty
water is pouring out of my 5 year old karcher from the trigger handle WHY???
May 22, 2010 | Karcher PSI Electric Pressure Washer
I HAVE A G30500HR PRESSER WASHER AND ACCIDENTLEY
Hey mate,
You should definately be able to get one of these at your local Karcher dealer, Ive worked at a karcher dealer here in australia and you can get any part you want for them...
Brad:)
Jan 02, 2010 | Karcher G3025OH Pressure Washer
Karcher 2400 Psi Pressure Washer No gain of pressure
remove the hose from the machine. Check that water is flowing. and there is no corrosion reducing the opening. If that is OK then it is the internal seals and pressure vallve on the pressure unit Cost to have it fixed by Karcher is $200
Thanks for using FIXYA
Sep 26, 2009 | Karcher 2500 PSI Pressure Washer
My karcher G2000QT WORKS AT HIGH PRESURE FOR A COUPLE OF SECONDS AND THEN STOPS THEN A COUPLE OF SECONDS LATER WILL START AGAIN WHATS GOING ON?
are you making the machine **** for water, if so you have got a air leak on the suction hose.
try force feeding with water by connecting your hose to the mains water hose and see if you can see a water leak.
could be starved of water also,chack the filter
Jun 28, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
125 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
