Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore refrig when i went home the other day from work i went to get some ice cubes out of the frezzer and noticed that they had started to melt and that the frig was not running. The inside of the refrigerator was not warm but things were not cold either. at first i thougth we had lost power but we hadn't, then i checked the fuse box but everything was ok there. One of my neighbors came over and was pulling the frig out so we could look in the back and all of a sudden it started to run. Any ideas why this is happening? It only 8yrs old. Thank you
The problem is not fixed. i didn't realize i had to join a program to get some advice. Thanks but No Thanks
Posted on Jul 03, 2008
Temp Rising in Bottom Freezer
You may have a freon leak but check the obvious first. Are your coils clean? Are the condenser and evap fans both running? Is there any ice or frost buildup on the back panel in your freezer?
Nov 09, 2013 | Kenmore Refrigerators
Suddenly, the temerature of the refrigerator and freezer went up to the point that the ice cubes and ice cream melted. Sounds like the compressor is working. I may have left a door ajar for quite a few...
try unplugging it for a day a so to let the evaporator coil defrost. When left open for long periods the evaporator coil will build too much ice blocking air flow. You might have apuddle of water under the fridge after the melt. -->
c_getProfessional_AskGet_refreshPicture(); if (!window.unique_ord) { unique_ord=Math.random()*10000000000000000;}document.write(''); 817-grey.gif
May 22, 2011 | Kenmore Side by Side Refrigerator
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Quit working
then there may be some voltage problem
Jun 23, 2008 | Amana ABB1927DE Bottom Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
