Question about E-Machines T3624 PC Desktop
Mouse and keyboard not working / recognized by computer
Power surge yestarday morning. Did not effect the other 3 computers in office.
Emachines T3624 now has a mouse and keyboard not working. The mouse and keyboard are fine, have tried them on other computers.
Can not solve any problem without a control device to use. Can you help me?
Cathy
  • 2 more comments
  • kt467 Jul 16, 2008
    Mouse and keyboard are not working. The lights are on but the computer acts like they are not plugged up.
    I tried them in all the USB ports and same thing. The keyboard will work when I start up machine and click start up menu. Then when system boots up nothing.
  • Anonymous Aug 14, 2008
    My mouse stopped working all of a sudden. Could it be something that the anti-Virus prompted me to remove?
    Can you please avail me with a list of any keyboard shortcuts i can use. I have seen people using computers with almost no need for the mouse.
    Thank you,
    Thimmo.
  • chandrakanth reddy May 11, 2010
    cathy,
    can u see windows xp loading or other operating system you have is getting loading?
  • Dan rogers
    Dan rogers May 11, 2010
    so the mouse moves but won't click?
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Posted on May 29, 2010
Need to be able to connect to my computer . plugged it in but computer does not recognize the mouse . red light is on
My computer doesn't recognize my mouse and its not listed in ...
www.tomshardware.com > ... > Windows 2000/NT
Tom's Hardware Guide
Mar 25, 2012 - 9 posts - ‎7 authors
please help.....I am using my keyboard to move my mouse keys and it really sucks. After a storm everything came out fine on my diagnostic ... My computer doesn\'t recognize my mouse and its not ...
Feb 28, 2013
Mylaptop doesnt recognize the usb for my mouse ...
Jan 27, 2013
Computer won't recognize keyboard or mouse - Mice ...
Aug 27, 2012
Computer won't recognize keyboard or mouse? [Solved ...
Aug 6, 2011
More results from www.tomshardware.com
Mouse doesn't work in any USB port - Tom's Hardware
Jan 21, 2016 | Onn Optical Mouse
I turn on my computer and although the mouse and the keyboard are connected they won't work. I am sure the mouse and the keyboard are fine. There is something wrong with the desktop.
Base from the description of your problem it seems that your computer is having some issue in recognizing your mouse and keyboard.
So what you can do here first is to power off the computer manually by pressing the power button until it shut down, then once its OFF unplug and replug your mouse and keyboard from the computer then power it back ON and check if its fine now.
Nov 30, 2010 | E-Machines eMachines Desktop PC
The T4010 emachine does not recognize the keyboard, but does recognize the mouse, is the answer a new motherboard?
If replacing the keyboard (try a USB keyboard, instead of a PS/2 keyboard) does not help, and the old keyboard _does_ work when connected to some other computer, then a new motherboard is the next logical step.
Jul 03, 2010 | E-Machines eMachines Desktop PC
Keyboard not working
I presume it is a PS/2 keyboard one that plugs into the Green Connector at rear of PC, if so, then these ports often fault, with the mouse being OK. The best way around this is to get a cheap USB keyboard, and install it. Ensure you set the USB ON in BIOS too. You could try uninstall/reinstall of KB from device manager first.
Feb 08, 2010 | E-Machines eMachines Desktop PC
Keyboard/Mouse not working after power supply replacement
Hello there:
ok first remove both the keyboard and mouse
and restart the computer and see if it says anything about no keyboard or mouse present if so this is good now just turn off the computer and install the mouse first and reboot and see if the mouse is able to work and than do the same for the keyboard. please try these first and please let me know how this goes, there is more that we can do if needed ok please dont forget to rate this for me
best regards mike
(usn retired)
Aug 04, 2009 | eMachines EL1210-11 PC Desktop
Cpu turns on but nothing else does.
Well, when my emachine did this, I was informed the "power toggle" was "gone" and that basically it would cost more to fix than to replace. I suggest you have this looked at as I suspect you will be given similar information.
Wish I had better news. Good Luck!
Feb 19, 2009 | E-Machines eMachines Desktop PC
PLEASE HELP ME!!!!!!!!!
Test your power supply for correct voltages. If they are all OK, then your motherboard is toast.
May 13, 2017 | E-Machines eMachines Refurbished EMA...
Keyboard not recognized
I'm assuming it's a wireless keyboard?
Have you tried "ReSyncing" the keyboard?
1) On the base unit for the keyboard/mouse plugged into the computer press the button on it.
2) Press the button on the bottom of your keyboard.
3) Try to use the keyboard.
You might have to try it a couple of times. That'll fix the problem 99% of the time. The other 1% means your keyboard is dead.
Oct 08, 2008 | Logitech Cordless Desktop MX3200 Laser...
Gateway 610 k/b & mouse unrecognized..CMOS problem??
It's not the K/M, there probably was a surge that went through, and effected the motherboard in the computer. so you can take it to your local computer shop. But, before you bring it there, back up your important files because they might have to format your HD.
Jun 11, 2008 | Gateway Media Center 610XL PC Desktop
Mouse and Keyboard not recognized
i think ur computer hangup after booting
there may be some problum in ur op system . it hase virous.
2nd u test ur mouse and keyboard to another computer if they work correctly u have to reinstall ur op sys
u can call me 91-9329204658 india
Jun 01, 2008 | E-Machines eMachines Desktop PC
E-Machines T3624 PC Desktop Logo
232 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
