Question about Samsung AS18A6RB Air Conditioner
Split unit a/c - works but no cool air only air. I was told the compressor broke and would need to be replaced at a huge cost.
Compressor broke after six years, one year after warranty. Considering the cost of the unit,I think the unit should not have broken after only six years.
    Novelist:
    Champion:
  • 230 Answers
The warranty usually reflects the worst case life expectancy. In other words if your warranty is for 5 years then they expect that if the unit was to be run consistently with regular to no maintenance It will only last 5 years.
These systems are very expensive. But that is not because of there longevity but for their unique applications. Manufacturers are not selling nearly as many Mini splits as they do regular split systems. So it is really just a supply and demand situation.
Posted on Jul 03, 2008
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Blower fan running but compressor not coming in.What could be the problem
To get proper cold air set temp 23 degree and mode"cool". If still no cooling, check power in out door unit. If power on, check compressor is working. If not working call repairman to find out exact problem, as there are many reasons for compressor not operating. Thanks.
Jan 01, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
Thermostat dial broke and huge ice pushed out cover. Fan still works ok.
dear sir
i think in your air conditioner,s thermostat is not working because there huge of ice on unit. thermostat control to compressor for desire temperature, when temreture reach till desire tempreture it,s cut supply for compressor . and make balance on cool air.
please replace thermostat for solve this problem.
hope answer the question
thank you
please vote!
Oct 02, 2010 | Sharp AF-R100DX Air Conditioner
Ramsond Split system - R55GW - will not cool or heat
That would be the way to go even thought the cost is high. If not you run the risk of compressor failure and the metering device may be clogged. I know the price is what has you over a barrel but, the cost to you in the near future will be 3 times as much.
Sorry I could not cure the problem over the internet
Also check around there may be someone who could do the job slightly cheaper.
Dave
Jan 15, 2010 | GE Quiet-Aire Ductless Split System Air...
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
Compressor keeps shutting off after 30mins or so
The system may be going into cool down mode or thermal over load if the temperature is 104 degrees fahrenheit or above since the compressor will shut down if the internal temperature reaches 165 degrees.This could also be from low oil in the compressor.
May 19, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Hitachi Soleus split Not blowing cool air.
if the freon is 410a the pressure must be 100-120psi,if it is 22 the pressure must be 45-55psi.you unlucky because hitachi havent problems with compressors.is it inverter the unit?if it is you must check the outdoor pc board,if the 4valve clicking in the you must replaced it propably has stucked.
Jun 19, 2008 | Hitachi RAS-09UH Air Conditioner
Not cooling
every single component in your cooling unit is needed for it to work, so anything can shut it down. If you could provide more information as to what type of unit you have: is it a central heat and air package unit? or central split system (furnace indoors and condenser outside)? or a wall a/c? Does any part of the system/unit do anything?
Apr 27, 2008 | Heating & Cooling
Samsung AS18A6RB Air Conditioner Logo
213 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
