Question about Mad Dog Multimedia MD-16XDVD9-EXT DVD±RW Dual Layer Burner
Phone number after bouncing you around 3 times, you get a personal phone answering machine that says you have the wrong number if you're calling for technical support. The website is also down. What am I supposed to do now? After 4 months of use, the pos won't even turn on.
Check with the manufacturer of the device, mad dog does not make any devices, they just repackage other companies devices
Posted on Sep 22, 2008
  • blaster3 Sep 22, 2008
    i have several mad dog dvd drives that are actually samsung writemasters
Temperature and depth reading is bouncing around all over. Is that something I can fix???
Popular Mechanics - Jan 1961 - Page 139 - Google Books Result
https://books.google.com/books?id=XNsDAAAAMBAJ
Vol. 115, No. 1 - ‚ÄéMagazine
Right, plates of full depth and weight ... Loose hold-downs - bouncing arounddamages a battery several ways ... Excessive loads - using the starter to move thecar should be only a ... ask for a temperature-corrected hydrometer reading, which should be 1.260 specific gravity. ... All this is dependent on the individual car.
Ask the Experts - USA Today
temp gauge bouncing around before going to center? ' Yahoo Answershttps://answers.yahoo.com/question/index?qid...Sep 28, 2013 - I called my mom and we switched cars and she didn't see anything ... Best Answer: If the temp gauge is literally "bouncing around" this is more ...Why is my temperature gauge jumping?Jan 1, 2013Temperature gauge bouncing.?Dec 18, 2008What does it mean, when my coolant temp needle jumps up and ...Oct 3, 2008My car temperature gauge keeps bouncing around from cool to red ...Dec 12, 2006More results from answers.yahoo.comTemperature Gauge Jumping Around an
Jan 23, 2016 | Cars & Trucks
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
HOW TO CONNECT A 3 WAY CALL
After you call the first person press the shift button or green phone button on your phone. You will hear a dial tone to dial the other persons number.After you dial the number press the shift or green phone button again to bring you back to the first person you called. You should still hear the phone dialing the other person and when they answer you will have a 3 way call.
Mar 12, 2011 | Cell Phones
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
Phone numbers
Try changing the advanced fax setting rings to the same style of rings as distinctive ring-All, two shorts, two longs etc.
Apr 29, 2009 | Vtech 5.8GHz Analog Cordless Phone
What is PUK?
hi im josh in phils. try this answer.
PUK is an abbreviation for the phrase personal unlocking key used in GSM mobile phones. Most mobiles offer the feature of personal identification ...
security code unlock the SIM. Blocking occurs when entering the PIN three times mistakenly. These acronyms come Staff Unblocking Code.
Personal Unblocking Key, if the PIN number has been entered incorrectly 3 times the phone will be blocked. ...hope i explained it.
Mar 05, 2009 | Samsung SGH-c417 Cellular Phone
RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Oct 27, 2008 | RCA 25205RE1 Phone
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Apr 01, 2008 | Uniden TRU9488 Phone
Setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
Dec 16, 2007 | GE 28112EE2 Cordless Phone
Mad Dog Multimedia MD-16XDVD9-EXT DVD±RW Dual Layer Burner Logo
186 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
