Question about Sharp Office Equipment & Supplies
SHARP AR337 COPIER - CODE H5-01 (EXIT SENSOR PROBLEM) MACHINE INOPERATIVE
  • Anonymous Mar 18, 2014
    how to enter programm code in ar337 sharp
  • 148 Answers
This code means you have had to many paper jams in the fuser without removal or sensor is bad. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttonsas follows.
Press the P, Press interrupt, Press clear, Press interrupt, Enter # 14, Press start, Press execute to reset, Press clear all or cycle on/off.
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
How to clear error code c1-00 on my sharp ar337
Main charger unit above drum has problem, clean it.
Jun 28, 2010 | Sharp Office Equipment & Supplies
My sharp AR337 always showing E7-11, when i clean
clean white surface under the glass.then push scale on the glass and make copy.few push glass holder metals near copy lamp.
May 14, 2010 | Office Equipment & Supplies
My sharp AR337 always showing E7-11, when i clean the lens, and mirrors the problem rectifies but the next day it comes again.
E7-11 is white level calibration error. This code was intended to identify a dirty white level reference (located under the left edge of the copyboard glass). Try to replace it as well as the bulb.
Mar 24, 2010 | Office Equipment & Supplies
How do I reset Sharp Copier AR337 service code U2-11?
counter check sum error
press the following keys in order program interrupt clear interrupt
the disply should flip to service mode
type in 14 press the start copy key
touch the execute on the screen
press the clear all key
my guess is it will come back and you will need a service call
Feb 16, 2010 | Sharp Office Equipment & Supplies
Looking for a Feeder unit for a Sharp AR-337 ????
The AR337 comes with a standard document feeder with a model number of AR-RF1. If you're looking to purchase one from a 3rd-party or from Sharp you'll need to reference that model number.
Aug 13, 2009 | Sharp Office Equipment & Supplies
Error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Apr 14, 2009 | Sharp AR-M350U Copier
Error Code F1 on Copier Sharp AR201
F1 means "shifter Motor Trouble". The motor that driver the shifting mechanism at the paper exit side is not functioning. The motor could be bad or there may be something binding the motor up. Take a real close look at the exit unit (where the paper comes out of the machine) and see if there is anything in the way of the shifter. It could also be a bad board issue - sending the wrong signal to the motor... or possibly a bad home position sensor for the shifter.
You could try taking the shifter unit out for a closer inspection - make sure its properly installed.
Hope this helps.
Apr 13, 2009 | Sharp AR 201 Copier
Duplex printer
Check the driver you have installed on your computer, that's where the duplexing would be generated from. You should be able to choose through print properties at this point. Here's the link to Sharp:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Sep 10, 2008 | Sharp AR-507 Copier
Sharp-275 Not a simple paper jam
This sounds like you may have a bad jam detect sensor, there is a sensor on the exit end of the fuser on the right and the flag for this is located in the middle of the exit guide on the fuser this gives us most of those types of jams.
Hope that helps...
Jun 16, 2008 | Sharp AR-275 Copier
Sharp Copier AR-C270 Code Problem
jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Jan 30, 2008 | Sharp AR-160 Copier
227 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
