Question about Intel Motherboard
Please Help 911
Hi! I just buy my motherboard P7N SLI and i'm having problem staring it back, I had aready install everything, it seem like it was working fine when i turn it off last night.
But right now i just try to turn it back on and it just tells me, Erro loading operating system, and i don't know what to do next. please help me.
    Sergeant:
  • 287 Answers
Ok first check your BIOS and ensure that the correct drive is selected to boot from.
Posted on Jul 17, 2008
No post no beep
check your hard drive and make sure it's connected properly and set for master, not slave.
Feb 14, 2010 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
I am not able to get my computer to turn on could this be a problem with the cmos battery on the motherboard. Everything else works I tested them on another board
Hi valsol138,
All you need to do is go to a drug store and get a Energizer CR2036 battery and replace the one on the board.
Good Luck,
Mark
Sep 21, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Can we install dot net in p3 1.3 ghz system
yes sure u can install the .Net Framework on your pc. after installation it may support your windows a bit, and your pc will be faster then before it is...
good luck
shafky
Jun 19, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Bios don't boot on p7n platinum sli
check the voltage on the power connector going to the hard disk.
it should have 12volts in red and black wire and 5volts on the yellow and black wire.
the main problem the optical and hard disks can't be recognized is the low voltage supply the drives gets.
Apr 13, 2009 | Intel Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
I have a problem with my ram
That motherboard does not have a video circuit built-in, so the video sharing the system RAM does not make sense.
Have you checked the valid system memory configurations in your MSI manual pg 2-7 ?
Any chance that the bios is set for dual channel and you don't have equal chip sizes in the dual slots? Example : In dual-channel mode, equal size chips would go in slots 1 & 3 and in 2 & 4
Defective RAM is a possibility also.
Note1: Per MSI, all ram may not register correctly in windows unless 4 of the 2GB chips are used
Oct 25, 2008 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Intel Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
