Question about T-Mobile Sidekick® 3 Cellular Phone
Track Ball My track ball rolls up, down, and to the right but for some reason when I spin it to the left it doesn't do anything. I mean it rolls to the left but it doesn't move on the screen - any ideas?
    President:
  • 625 Answers
You may need to do a cleaning on it. Usually a dirt and dust get in there and block the little sensors.
Check out the following link for the procedure to clean your trackball and a video demonstration.
How to Clean Trackball on Sidekick 3
Posted on Oct 06, 2009
    Problem Solver:
  • 14 Answers
Your track ball may simply be dirty. Get a q-tip wet with rubbing alcohol and rub your track ball and repeat until the q-tip stays clean. Hope this helps!
Posted on Sep 16, 2009
Blackberry 9630 Trackball not working in the main menu
hold down alt key and swipe roll the ball. for emergency purpose. ferrah.com@gmail.com
Dec 10, 2011 | RIM BlackBerry? Tour 9630 Smartphone
My blackberry scrollball is not working. It canonly go left to right and vice verssa but can not move up or down
Have you tried cleaning it? The best way I clean mine is using a q-tip, dabbing it in rubbing alcohol, be sure to squeeze the excess out of the q-tip, and roll the wet q-tip all around the ball. Make sure you roll the ball so that all of it gets the alcohol on it. You can use the other side of the q-tip (dry side) to dry the ball.
Hunnybunny11
Jan 24, 2010 | Cell Phones
Blackberry ball wont roll
If the track ball is stuck, there's something that's preventing it to roll. Cleaning it should be the solution, but you need to contact the manufacturer and have them clean it for you. Because that track ball is not easy to remove.
Thank you!
Dec 29, 2009 | RIM BlackBerry Pearl 8100
When I roll the ball to the left, the cursor doesn't go to the left?
change the trackball sensitivity
Steps :
1. Click Menu Key
2. Go to options, under that select Screen/Keyboard
3. scroll down you will get track ball settings
Horizontal sensitivity
Vertical sensitivity
increase the sensivity to 100 then you will be able to roll track ball,it will work fine....
Oct 30, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry pearl
Common faults with Pearls, do you have warrenty on the Phone?
Send it back for replacement as its hardware fault.
I hope this helps,
Thanks.
Mar 07, 2009 | RIM BlackBerry Pearl 8100
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Window
YOU HAVE A BAD WINDOW REGULATOR WHEN YOU ROLL IT DOWN IT COMES OFF TRACK SO WHEN YOU ROLL IT UP YOU RUN INTO THIS ISSUE
Nov 08, 2008 | 1996 Honda Civic
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl
First, turn off the device. While pressing down firmly on the track ball roll the ball in all directions.
If that doesn't work, then you may need to take out the track ball and blow it out with compressed air. The link below shows how to disassemble the track ball:
Oct 01, 2008 | RIM BlackBerry 8700c Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
116 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
