Question about Xerox Phaser 8400 Laser Printer
Phaser 860 Printer posting a paper jam at start up.
My Phaser 860 Printer posting a paper jam at start up after an employee moved the printer and spilled the ink inside. At first it started up making a clicking noise. I took the right side cover off and observed the clutch was out of alignment. After moving it up & down before power up it finally started to warm up. It them finished warm up and attempted to print and then jammed. I removed the jam and observed a lot of wax ink clumped at the edge of the paper. I removed the jam and it attempted to print again jamming. I again removed the jam and again attempted to print. This time I removed the jam and found a lot of wax ink clumped to the left corner of the page. I removed again but continued with the paper jam. I looked in the paper path and found a small white piece from one of the exit rollers above. I removed but broke the little flag on the lower exit pivot guide. I have ordered replacement parts, but suspect it may still failure with paper jam error. Any ideas?
  • Anonymous Mar 26, 2014
    when the unit is powered on, it goes through warmup then flags a duplex jam. zone 3 removal but there is no paper. I see the actuator for the duplex and it moves freely. Is there a bulletin or something else I am missing. I seem to be missing the actuator that sits above the cassette.
  • Anonymous Mar 27, 2014
    how to removed paper curled around roller just below the ink pack? model is envy 4500.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Posted on Jul 18, 2008
Jamming when duplexing
Anonymous,
Look very closely at the area of Jamming don't just rip out the paper without investigating where the edge of the paper has moved through the printer for your clues to solving the issue.
Good luck.
Jul 28, 2014 | Xerox Phaser 8560DN Laser Printer
Phaser 860 Phantom Jam Won't print until jam in
There is a solenoid on the transfix assembly that has a tendency to "stick" in the open position, causing paper jams at the exit. The Solenoid is located on the right side of the machine, at the top area in the middle. You can test it with your fingers to see if it sticks in the up position. If it is, simply clean the sticky residue off both metal surfaces with alcohol and it should return to normal operations.
Aug 26, 2013 | Xerox Phaser Office Equipment & Supplies
I have a phaser 860 and it has a paper jam issue. There is no paper jam. I am wondering if the maintenance roller can cause this? It has been sitting around for well over a year and I just started using it...
Most likely if it is not moving the paper out of the tray the rollers will need replaced. You can try cleaning them a few times with soapy cleaner, and alcohol.
Honestly, you could probably pick an entire 860 up on E-bay for cheap for some of the parts, But feed rollers I would get new.
Not sure of a non Xerox source for those. You can try Precision rollers, The Parts Drop, and Xerox phone number to order those parts would be 1-800-835-6100, follow prompts to parts and you can just inquire. They will give you prices and look up what you need with no commitment.
Jan 19, 2010 | Xerox Tektronix Phaser 850N Laser Printer
Why is this tekronix 860 printer kept flashing error message saying missing upper tray. However, all trays are intact. It looks like a sensor issue
Tektronix printer paper trays, I seem to recall that there's a plastic key that fits on the right side of the paper tray. It's a little plastic piece that just clips in on the right side of the paper tray. Sounds like it's missing
May 18, 2009 | Tektronix Phaser 860 Thermal Printer
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 860. I replaced maintance kit and it came up with sevice a
--> The yellow ink sticks are jammed.
Open the ink loader and ensure that the yellow ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks. And use the link below for any other problems you may have.
Niallbt
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=117,E=0000000000024637030,K=5840,Sxi=17,command=restart,ques=user_type:4,ts=xo_legacy,varset=prod:860
Mar 08, 2009 | Xerox Phaser 8500/DN Printer
Printer error
hi!!!
try to re-install your printer driver
may be it helps!!!!
Oct 26, 2008 | Office Equipment & Supplies
Xerox Phaser 860 ink scratches off sooooooo easily
An 860 has no fuser. That sounds more like either a maintenance kit or transfix roller needs replaced.
Jul 11, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8400 Laser Printer Logo
377 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
