Kranzle 105 pressure washer. wiring ok. Motor buzzes but will not turn, give the fan a little flick motor spins fine,but will not spin on its own accord....
  • Anonymous Nov 16, 2008
    Does not turn over. Hums. Very little flow.
  • 47 Answers
Weirdo's. didnt even read the question correctly.
it's a pressure washer not a washing machine.
probably the caapacitor is low
Posted on Nov 18, 2012
  • 135 Answers
SOURCE: ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Posted on Apr 07, 2008
IrishDruid
  • 2712 Answers
SOURCE: not spinning
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jun 14, 2008
SolutionGuy
  • 331 Answers
SOURCE: frigidair washer will not drain or spin
MNM,
I suspect that your "lid lock" mechanism has gone to appliance perts heaven. If the timer "thinks" the lid isn't completely closed and locked, it'll shut everything down when it's time to spin and drain. It's a safety feature... I mean, you wouldn't want this thing spinning at full speed and have a 5 year old lift the lid and stick her paw in there only to have it torn out of the socket, would you? Yuck! (was that too graphic?)
Anyway, here's what I'll need you to do. You gotta get access to the lid lock and run a TEMPORARY bypass on it to verify my theory, OK? You'll also need to UNPLUG THE MACHINE BEFORE DOING ANYTHING ELSE!!!! If you don't, you run a high risk of a funky new do and some time in the Hospital.
Click this link, you'll see a main picture and 4 "thumbnails"... I want you to look at the last one. It'll show you a micro-switch in detail. This is what I believe to be at issue and this is what we'll bypass for testing purposes. All you need to do to access it is remove the front panel.
Look at the lower right and left of the front panel, you'll see 2 Phillips screws there, remove them. Now grasp the front panel and pull straight down to unlatch it from its' clips. Then pull the panel toward you and set it aside. Now that you can see inside the cabinet, look to the top right and you'll see the lid lock. Since you've UNPLUGGED THE WASHER, you are not afraid to remove the 2 wires attached to the switch (shown in the link above).
Now that you have the wires off, you'll need to build a "bypass tool". My favorite (and the one I carry in my tool bag) is made from a paper clip. Take a paper clip and straighten it all the way out. Then bend it into a "U" shape. Starting at the bend, wrap it with vinyl electricians tape most of the way up to the exposed 2 prongs (leave about 1/2" exposed). Now take these prongs and insert one into one terminal and the other into the other terminal. Make sure they are firmly and completely seated.
Now plug the machine in and set it to spin. I suspect that it fired right up. If it did, we just verified the failed component... the lid lock assy. You can buy it online by plugging this number (134101800) into a search engine, or pick one up at a local appliance parts retailer.
IF, and only if, this didn't fix your problem, write back to me and I'll take the diagnostic a little deeper for you. Otherwise, please don't forget to rate this as "FixYa", OK? (It took me longer to write this than it would have to fix it, so show some love, K?)
SG
Posted on Apr 16, 2009
  • 11 Answers
SOURCE: Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
Posted on May 29, 2009
jsrock516
  • 5911 Answers
SOURCE: Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Posted on Oct 04, 2009
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
My clothes dryer doesn't spin by itself
Motor capacitor, it gives the motor a little extra kick it needs to start
Sep 17, 2014 | Dryers
Makes electrical humming noise but does not pump water
This is could be the capacitor that has failed. The capacitor gives the motor the initial kick in the right direction to get it started. You can confirm it is a failed capacitor and that the motor is still ok by flicking the fan blades with a stick in the direction it should spin just as you switch the pump on. The pump should run normally. You can get them off Amazon or ebay for around 5 Pounds (GBP)
Oct 11, 2010 | Karcher K2.26 Electric Power Washer
Washer will fill spin and drain but will not wash
  • first check the motor power supply whether it is fine or not
  • next check the motor coil whether it is working or not
  • If both are ok the motor power supply and coil is fine means you are suppose to check the pressure starter since it is giving the signal to the wash motor to run
  • kindly change the pressure starter to solve your problem
May 14, 2010 | Washing Machines
Kranzle Pressure washer...seems to be no power to the machine..checked switch and all connections all fine but no power to the machine
Could be that the fuse in the plug needs replacing.
Does the machine make any noise? Does it buzz/hum when you try to turn it on? - If yes, a starting capacitor is required.
Nov 19, 2009 | Electric Kranzle Professional 1600 PSI...
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
WHDSR209D Washer
if you have a rubber smell that means that the belt is burning through. Several problems can be the case.
1 bearing of the drum ( check if it turns freely if so the bearing is ok)\
2 the belt is worn and need to be replaced.
3 carbon brushes in motor are worn
4 bearing in motor is gone
open the backside of the machine and check belt.
think that is your problem
Apr 30, 2008 | GE WBSE2090A Top Load Washer
Washing Machines Logo
343 people viewed this question
Top Washing Machines Experts
