Question about Toshiba 52HM95 52" HDTV Projection Television
I have vertical lines across my tv screen, what would cause this? Thanks
  • 1 more comment
  • Anonymous Nov 21, 2008
    This is the Second Toshiba 52LX177 and both TV's have had 3 to 4 vertical lines a pixel or two wide appear on about a 1/3 of the screen from the sides. To have 2 TV's have the same problem when the repair people say they have never heard of this is extremly strange. Anyone have any idea what would cause this.
  • Anonymous Dec 08, 2008
    I think my Horizontal lines come on my tv when i watch programmes through sky.
    When I watch through normal TV it is fine.
    Any help
  • Anonymous Mar 06, 2009
    I have the same issue with about 6 lines going vertically across my screen ranging in size from one inch to about twelve. I have the 52" lx177
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
Posted on Nov 03, 2006
frolona_road
  • 95 Answers
SOURCE: Why would there vertical lines on my toshiba theater wide tv?
this sounds like a bad capacitor. If you want to fix it yourself and know how to solder on a pcb, then replace all of the electrolytic capacitors.
Posted on Nov 18, 2011
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
HI When I start my ALBA TV, there are horizontal lines across the screen with high noisy sound. I bought this TV just few months ago. thank you
The horizontal line in the screen is the problem cause by vertical output driver.The vertical output is located at the verical section.Maybe theres a loose connection in vertical section or leaked capacitor.It also the cause of deffective vertical ic.So its better to repair and trouble shoot by the authorized technician.If you have knowledge in Tv.Try to replace the leaked capacitor.
Jul 17, 2011 | Televison & Video
On power up I hold the power button down, I can hear some sort of relay kick-on, sometimes a horizontal white line appears across the screen, then it kicks-off, and the red led blinks four times...
White line across the screen indicates that tv got vertical deflection failure problem that may be due to vertical output chip failure. If that kind of problem occurred, tv select protection mode and red light starts blinking 4 times.
Please check vertical output chip in tv main board and replace it to solve tv issue. This job needs soldering work so local tv repair shop will help you.
Thanks.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
27" flat screen
The main cause of this problem is cracked solder joints on the vertical output IC. Re-flowing the solder should take care of it. Sometimes a capacitor (normally against the heat sink containing the vertical output) will cause this, but, it usually has a different symptom. The price of repair will normally run, depending on where you live, $100.00 to $130.00. It's a small job and is done quickly. Hope this helps.
Mar 17, 2007 | Toshiba 27AF41 27" TV
Toshiba 52HM95 52" HDTV Projection Television Logo
1,489 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
