Question about Panasonic Lumix DMC-FZ5 Digital Camera
Just not working right
The power goes on and off and the little screen works but none of buttons are working. I bought new batteries and it still isn't working. I can't even reset it. I saw in a previous question you told the person to do a master reset. How do you do that.
I had the same problem. my fz5 stop responding to input from the rear buttons. If you go to: http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/ at step3 you'll see the "rear control ribbon connector" highlighted. As I fiddled,carefully, around the ribbon came lose. It seemed a little to easy so I reconnected it and made sure the tiny black clips (you'll have to look closely) that hold the ribbon in place were properly engaged. Voila problem solved! Just make sure that, unlike me,you try this before you fork out on a new camera.
Hope this helps.
Posted on Jul 10, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
I'm trying to work this pro more HD camcorder but none of the buttons seem to work only the power button and the flash button work and ya
the wiring loom which goes to the screen have wires which are very
tiny and easily damaged if opening or closing the screen is handled
roughly needs checking by the experts.cheaper probably to buy a new one
Mar 14, 2013 | Cameras
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
Screen frozen TH8320U1016 honeywell
I got mine to work! Mine is the th8110u1003 and although the screen seemed to display, it was completely unresponsive to touch. Long story short, there is a flat watch battery behind the screen. Get to that and remove it for 15 seconds and reassemble. It powered right back up!
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Frozen screen
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
Sharp Elsimate 1611P 12 digit Calculator
It sounds like there is a printer error. Take of the cover where the paper is. There should be a little ink roller. Try taking this out and look in and see if the rubber band with the numbers on it is broken. If so, the machine is not worth repairing, unless you can get it replace under warranty. If it is not broken, try turning the machine on and off with the ink roll out of the machine. This should reset the print head as long as nothing is in there jamming it up. Good luck John
Jun 12, 2007 | Sharp EL-1611P Calculator
Panasonic Lumix DMC-FZ5 Digital Camera Logo
135 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
