Question about Hitachi 61SDX01B 61" Rear Projection Television
Convergence Error 3
When the Magic Focus button is pushed, No. 3 flashes in the bottem right hand corner. Based upon my research, its an A/D Level and Connect 1 Error. My question is: How can I fix this?
  • Anonymous Aug 15, 2008
    i have the same problem, help!!
    Genius:
  • 1,139 Answers
DCShelley,
This sounds like an A to D converter problem which may be linked to you convergence amplifiers. I would suggest that you have a qualified TV technician work on this set.
Thank you,
Shuttle83
Posted on Nov 25, 2008
Convergence
I presume it is Hitachi---if Magic Focus does not correct the problem--the convergence chips need to be replaced.
Based on a MODEL NUMBER several sites on the internet sell kits etc.
I am available to help if you provide me with a model number and some idea of your skill level.
Jan 17, 2012 | Hitachi Televison & Video
My Hitachi 50UX26B/27K red picture tube seems to be out of line with the blue/green tubes. When I press the magic focus it runs a short 30 second cycle then displays the number 3 in the bottom right hand...
Your convergence is fried go to ebay and order this item number 130475189383 copy n paste and put in ebay search.You will also need a delsolering iron, a soldering iron, some kind of skill soldering and patience.
Jan 18, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
When doing Magic Focus on Hitachi 51SWX20B I get Error 3, and the Process Stops. I have a Hitachi 60SDX88BA that also has a blue semi circle at the top of the screen. I have run magic focus and it stops...
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
Is there a Magic Focus function on 53XDF01B?
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergence issue Hitachi HDTV Model #53uwx10ba
you have a sensor problem to start magic focus is the last step in this repair done normally after replace converge outputs did you do this? if so a manual alignment is needed then you may write it into memory if you get a solid green screen after just briefly you have done it wright if you get a red screen after wards you need to try again it will stop on red if all is not well
Oct 08, 2008 | Televison & Video
Convergence hitacho 61swx10b
To enter digital convergence adjustment
mode without removing the front speaker
grill, please do the following:
1) Press “Magic Focus” button on the front
panel.
2) While “Magic Focus” is running, press
Magic Focus button again to “Stop”.
3) Press “RECALL” or “STATUS” button after
“STOP” OSD appears on the screen to
enter digital convergence mode.
4) Proceed with convergence adjustment
and save the data.
5) Do MAGICS FOCUS sensor initialization.
6) To exit, press POWER button on the front
panel.
7) Normal and through 1080i modes are
stored separately. Each one has it’s own
memory setting.
Aug 11, 2008 | Philips 60P8342 60" Rear Projection...
Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
