Question about Canon LaserClass 2060P Plain Paper Fax
Check Cover/Cart Message -
The above message appeared after a manager took out the toner to get the FX number on the bottom. I have referenced the manual on line and re-inserted the toner several times as to be certain it is in correctly. I have also opened and closed the front cover repeatedly to insure it is closed. I unplugged 3 times. The message is still there and the fax machine will not operate. I have several important documents stored in memory - can you offer any suggestions?
Thank you soooo much....Christine
If you open the front cover, there is a little white sensor you can see through a slot to the left. this is the sensor for the cover, i just fixed a machine where that little sensor was stuck down to the cover wasn't pushing it in correctly.
Posted on Sep 22, 2008
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
HP Deskjet 950C. Printing is coming out with one
1.driver problem
2.their may not be enough toner
3.virus in system
try to solve above may give the solution
Aug 31, 2009 | Office Equipment & Supplies
Muratec mfx 1600 drum replaced alarm will not reset
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
2 Press the scroll button ( or ) until “Ignore Toner”
3 Press the Scroll button ( or ) to select “On” or “Off”.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
"Waste toner tank full"message won't clear
I had the same problem with my printer. On the back of the waste toner cartridge is a tab that sticks out. A photoelectric shine thru this tab to let you know when the cartridge is full. My photoelectric had gone out and was giving the same error message. I took my printer apart and cut the wires loose on each side of the photoelectric and shorted them together to complete the circuit. The only problem in doing this is you have to occasionally check the waste toner cartridge yourself to make sure it does not overfill.
Nov 08, 2007 | Samsung CLP-500N Laser Printer
Canon LaserClass 2060P Plain Paper Fax Logo
158 people viewed this question
old marine
old marine
