Question about Bosch Dishwashers
Bosch SMS6032GB/20 worked fine the first time but does not pump water inside hence the dishwasher stops. There is 1/4 water already inside on the left hand side.
  • 161 Answers
TRy filling it with the sprayer from the kitchen sink . If it washes properly this way, look at the fill valve and the float assembly. Bosch uses a seperate pump for wash and drain. See if it can drain after the test.
Posted on Jul 03, 2008
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Bosch dishwasher starts, pumps, stops and says it's clean
We have the exact same problem with our Bosch SHE5AL06UC/05 dishwasher. Works great when it works, but we are increasingly having a hard time getting the wash cycle to start.
Apr 13, 2012 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Won't drain
I found a video that explains how to fix this issue, here is is.
Bosch Repair video
Feb 06, 2011 | Dishwashers
Hi We have a 1 yr old Bosch dishwasher SGS45C02GB-06. It's stopped working for the second time in a year. It stopped mid-cycle and the water is not draining away or being pumped away; although you can...
Did you install the high-loop for the drain hose? If not, you need to pull out the dishwasher and make sure that the hose is not lying below the pump at the bottom of the dishwasher. This will usually fix this problem.
Jan 05, 2011 | Bosch Dishwashers
I have just moved house and there is a Bosch Dishwasher installed unfortunately I have never owned a dishwasher before and there is no instruction manual with it. It has a model number,SMS6032GB/20. Please...
Call up Bosch Customer Care at 1300 368 339 in AU. Ask them for the manual and they will post it to you. I also had the same issue and they copied the manual from their archives and sent me the next day.
Sandy K
Apr 06, 2010 | Bosch Dishwashers
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
How do i remove the pump off my bosch dishwasher,as bottom 1 unit, any tips wont empty water cleaned all traps. is the a pump solenoid?
inside the dw remove all filters and in the sump there is a cover over the impellor with 1 self tapping screw remove and there could be a object stopping pump.
Sep 14, 2009 | Bosch Dishwashers
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
227 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
