Question about Sony TAM-100 Digital Answering Machine
Beeper signal How do I shut off the beeper signal that sounds when there is a message waiting. I want only the flashing light.
The link below is to the manual. scroll down to the bottom of the 2nd column to find "selecting the answering mode." there is a chart with the possible modes at the top of the next column. i personally couldn't get this to work on the current machine i use for whatever reason, but it did work on the one i used to have. maybe cutting the power and setting up the machine again would do it, or maybe you could just throw it out the window. answering machines are so 90's anyway; you can probably set up voice mail through your landline if you have to.
http://www.fixya.com/support/p121269-sony_tam_100_digital_answering_machine/manual-15443
Posted on Sep 03, 2008
When buttons are pushed, no beeping. even when timer is set to go off, no signal that the time has expired
If all other functions are working and you just lost the beep sound then you have to make this choice. The beeper is actually mounted on the main control board. If it has gone bad--the only way to fix it is to replace the complete main control board which is an expensive part. One thing to check in your owners manual is if your control has a way to change the sound level of the beeper. If yes--it may have accidentally got shut off if it has that type settings.
Jun 16, 2015 | GE JTP75 Electric Double Oven
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
How do I turn the beeper off so there is not beep at all on my Oster 5834?
You need to look in your owner's manual to see if turning off the beeper is an option.
The beeper is very important to inform you when the bread is ready, when to add ingredients, or if there is a problem with the maker. I am not sure it can be turned off.
Jul 28, 2014 | Oster 5834 ExpressBake Bread Maker
How do you disconnect a reverse beeping signal on a 2006 Toyota Sequoia?
I have found the beeper wired into the reverse lights and if you just find the beeper and cut off the wire and cap it you should be fine and no more beep.
May 05, 2014 | Toyota Sequoia Cars & Trucks
Turn signal flasher not loud enough
see previous poster, where he begs more quite.
in your case, add a 12vdc beeper to the dash flashing indicators.
if you have 2 indicators, add 2 diodes to the beeper , ask.
the best way is at the flasher, ( 2 diodes and beeper.)
beep minus to ground
beeper plus to 2 cathodes (band) 1N4004 diodes, (ubiquitous part) and the each ANODE to each side of flasher Left and right.
bingo , it makes more noise.
i can do a schematic easy, ask.
Mar 24, 2014 | 1999 Jeep Cherokee
How to stop door ajar and lights on beeper in vw beetle
Try resetting the computer. Take the negative battery cable off, wait 5-10 minutes then put it back on.
Dec 04, 2012 | 2000 Volkswagen Beetle
Doorajar liht and beeper sounds
It can be issue with faulty sensor or a wiring issue.Troubleshooting is required.
Click the help link shown below:---
Door Ajar Light and Dome Light Remains ON? http://whoisbyme.blogspot.in/2012/06/2003-mercury-sable-door-ajar-light-and.html
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Thanks.
Jun 26, 2012 | 2002 Ford Explorer
CRV Reminder beeper not beeping
you should start by checking fuses,switch located on door pillar where door hinges are.sounds like a blown fuse or bad beeper,
Oct 05, 2009 | 2004 Honda CR-V
Toyota prius beeper
you cant eliminate beeper yourself but if you taake it to the dealer it being so new they have to hook up the scan tool to turn of your beeper as long as its as factory system i work at a toyota dealer and we do this for cust a lot our computer has all the options in you car that are changeable due to the cust preference hope this helps
Mar 23, 2009 | 2009 Toyota Prius
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Sony TAM-100 Digital Answering Machine Logo
162 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
