Question about Sherwood Audio Players & Recorders
The tuner shuts down when volume is increased. Probably a fuse but where are they lcated on the Sherwood RX4 103
    President:
  • 624 Answers
It is not a fuse causing this. If a fuse was the cause, it would not turn on at all.
You may have a bad speaker, too many speakers, speakers connected wrong, a bad output channel in the amplifier, or even several other things.
let me know more details of how this is set up and how many speakers you are using, how many speakers per speaker jack, what type of speakers and the "ohms" rating on the back of the speakers where the wires connect into them and I may be able to help you figure this out.
Dave
Posted on Jul 02, 2008
Shut up stereo protect mode?
Protect mode is on because something in your speaker wiring is wrong, or you have a broken speaker, or it\'s too late and you already fried one or more of the amp\'s output transistors.
You gotta fix the problem. Not remove the safety guard and carry on with a busted machine.
Look for wires touching between the speaker terminals or on the backs of the speakers. If you done a half-ass job of wiring up then this is the most likely cause.
If you can\'t find bad/frayed wiring, then disconnect all the speakers out the back of the amp. Switch the amp on. Does it trip out? If no, that\'s good. Turn up the volume. Is it still okay? If yes, that\'s good. You haven\'t yet killed the output transistors. If it goes in to protect though, ut oh. It\'s Repair Shop Time.
If the amp is okay, then power off and add one speaker. Power on with the volume down. If it trips either at no volume or when you increase the sound, then you got a bad speaker and you just found it. Repeat the process, adding one speaker at a time. Make sure you put Vol to minimum and power off each time before adding the next speaker.
Sep 14, 2014 | Sherwood Rd-7405hdr 7.1-channel 70-watt...
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
Trying to hook up a wii game to the rear of the recevier need to know which jacks to use
Actually, most will work. AUX IN, LINE IN, or TUNER in will all accept the "line level" output of the Wii. Just pick one of those, start with the volume DOWN on the amp and fire it up. Slowly increase volume but if nothing is heard in the first 1/4 turn, you've probably got something hooked up wrong. Back it down again and try another input or check connections.
Dec 28, 2010 | Yamaha RX-V459 Receiver
Keeps turning itself off
If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
May 23, 2010 | Sherwood RX-4109
My speakers shut fown briefly even at small volumes. Help!?!
are the hooked up correctly positive and negative whats the ohm load of the speakers and amp could be a short in your speaker cables
could be many different problems
Jul 02, 2009 | Sherwood RX-4105 Receiver
Volume when on tuner is very different than when on DTV
Under the input menu, there is a volume trim function which allow you to increase or decrease the volume level of each input. It is designed so that the volume of different components can be matched to prevent a blast of sound when changing to a lounder output. You can increase the alevel of the dtv input, and decrease the level of the tuner. Tuner volumes are usually high.
Jan 24, 2009 | Yamaha RX-V1400 Receiver
TECHNICS SC-CH550 STEREO SYSTEM
Hi
I belive that you have a lot of dust how is gatherd behind the system in the amplifier and it is preventing it to cool down you need to blow it clean and make sure that you keep the system gets cool air
if the temp in the amplifier gets to high it shut down the system instand of burning it very clever solution from the manufacturer
you have a very good system good luck
Jan 04, 2009 | Technics SC-DV290 System
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
139 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
