Question about HP PSC 2110 All-In-One InkJet Printer
Hp psc 2115
My printer he dont lend me print. when i open it post a message ''OPEN DOOR. CLEAN CARRIAGE JAM, AND THEN PRESS ENTER.'' what to do pls help me. thanx for your time,.
  • erotokritos Jul 02, 2008
    my printer he dont lend me print. when i open it post a message ''OPEN DOOR. CLEAN CARRIAGE JAM, AND THEN PRESS ENTER.'' what to do pls help me. thanx for your time,.
  • Anonymous Dec 18, 2008
    Paper jam clear paper all 3 lights blink and canot reset tried all tricks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Posted on Jul 27, 2008
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
HP PSC 2210 has the error message 'Open Door, Clear Carriage Jam, and then Press Enter'. No paper jams present?
Check door for paper stuck in front of sensor. There is a door in the back look to see if paper shred is in there infront of the back door sensor.
Jul 27, 2010 | HP PSC 2210 All-In-One InkJet Printer
I keep getting a message: open door. clear carriage jam and press Enter. what do i do? I checked the cartiage and closed it and pressed enter and still get the same message
Dear,
Its a problem of purging unit it is in a right hand side of printer clean the surface properly and then check the printer.
bye
wasim
Jul 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
Cartridge jams
remove the cartridge and directly off the printer let the carriage remain in center.then with your hand manually move the carriage from left to right.3 to 4 times.then on the printer and insert the cartridge after cleaning it with dry tissue.then check out.also in the back side of the printer there is access door to remove the paper if jammed so check out there also if any paper jammed.
thanks.
Apr 01, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp probllem
Please check the following link and perform the steps provided.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00309142
Regards,
Sagar.
Jul 02, 2008 | HP PSC 2110 All-In-One InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP PSC 2110 All-In-One InkJet Printer Logo
175 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
