Question about Dryers
Not drying I have a Miele Novotronic T234C Condenser Dryer which is not producing any heat to dry clothes. Machine is a year old, is there anything I can check for faults please? thank you
  • 1 more comment
  • Anonymous Sep 04, 2008
    Have the same problem...
    Also a one year old dryer
  • Anonymous Dec 12, 2008
    I have the same problem and no solutions
  • Anonymous May 15, 2009
    miele t234c not drying only 3 years old
I had the same problem with my dryer.
MAKE SURE THAT POWER IS OFF AND PLUG IS UNPLAGED AT WALL
On the back of the dryer there is a white metal cover in the centre with two philips screws. Once removed you will see metal box which has elements like a toaster built inside it.
You will see two sensors sticking out of top of metal box. The left one is the sensor for safety cut out in event of the dryer sensor on the right stopping working and letting the dryer overheat.
If you disconnect the left sensor 2 crimps and put multimeter on the left sensor two pins and if the meter beeps on continuety the sensor is ok. but if no beep the sensor is bad.
If sensor bad you can tempary bypass the sensor by joining the two cables together and try running dryer on a program and if heats up you know that you need to get new sensor.
WARNING! IF YOU LEAVE THE LEFT SAFETY SENSOR BYPASSED IF THE RIGHT HAND SIDE SENSOR MALFUNCTIONS THE TEMPERATURE WILL RISE AND CAUSE SERIOUS DAMAGE OR FIRE. THE PURPOSE OF THE RIGHT HAND SENSOR IS WHEN THE DRYER HEATS UP TO HEAT IT CUTS OUT AND WHEN DROPS DOWN IT HEATS UP AGAIN SAME AS AN OVEN.
You can maybe buy sensor from a meile dealer or RS COMPONENTS have the same sensor for £3.35 each.
NOTE: I ACCEPT NO RESPONSIBILY FOR DAMAGE OR INJURY IN MY ADVICE FOR REPAIR OF DRYER.
Posted on Dec 12, 2008
Have the same problem, so thats the fridge freezer the tumble dryer and the washing machine all miele all broken down this year and none over 4 years old, Miele are absolute ****.
Posted on Sep 23, 2008
Miele novotronic t 1526 dryer taking too long to dry clothes. It does dry but now ~2-3 times longer than it should.
Dear Arland,
Here are a few common answers.
1) Be certain the clothes from the washer are already "half dry".
If the washer is not extracting enough water like it used to, it may be the problem. (For example: A loose or slipping drive belt).
2) Your dryer vent may be clogged with lint.
Check the total run of the exhausted air ( From the machine to the outside air)
Any blockage can slow, or nearly stop, the drying process.
3) Check the inside of the machine.
Newer machines often clog up inside where you cannot see the problem.
You must completely dismantle the machine to clean it.
God bless your efforts.
Feb 17, 2017 | Miele Dryers
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
How can I reduce the humidity of the air expelled from the dryer?
If the aire being expelled is humid then this suggests that the unit if working fine. if clothes are still damp then maybe give them a second spin before putting in the drier, or dry them for longer. Also try putting less in the drier and drying in two loads.
Oct 19, 2014 | Miele Novotronic T230C Electric Dryer
My Miele dryer Miele Novotronic 494C does not dry clothes
Check breaker, then wiring. This can be a thorough job. Your element is probably burned out. If it is older than10-12 years,this is normally it. One other thing to look at is the relay switch which is located under the top. It will shut down if there is an electrical problem.
Mar 15, 2013 | Miele Dryers
My Miele T294C NOVOTRONIC TUMBLE DRYER KEEPS STOPPING AFTER A FEW MINUTES OF DRYING. I CAN SWITCH IT BACK ON IMMEDIATLY ONLY FOR IT TO STOP AGAIN. CAN YOU HELP?
Hi - it seems likely the moisture sensor unit is faulty, reason?
Well Miele dryers after you start up will actually try to work out the amount of moisture in the dryer, it will calcualte the time & temp required to correctly dry the load in the machine. I suspect the sensor is not functioning proper.
I will assume there are no messages or other indications or flashing lights on the right side of the knob - it would be nice to plug my laptop to it and find out for sure..
You have cleaned the heat exchanger unit in the bottom corner of the dryer, the filter in the door and the two on the bottom of the door opening..
Despite all of these I would lean on the faulty sensor as the most likely culprit.
You may have to locate the nearest Miele service agent to help you out...
cheers
Jun 22, 2011 | Miele Dryers
I dont have manual for miele T5213 so cant tell - should heat button be pressed in for low temp. Doesn't seen to have time difference when drying towels
hi i have a miele t5213 dryer it was ok yesterday but today it is
not getting hot can you help also i dint have a manual for this
machine i lost it during moving house
regards jeff
Sep 19, 2010 | Miele Novotronic T1570C Electric Dryer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Clothes not drying in condenser tumbler dryer
Sounds like your heating element is burned out (acually burned threw) I can walk threw it with you if you like.First find a replacement element.Everytime you turn it on the element gets weak from contraction and expansion.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Miele Novotronic T220 Electric Dryer
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Dryers Logo
1,613 people viewed this question
Top Dryers Experts
