Question about Pyramid 906 Car Equalizer
Installation trouble I have wired my equalizer according to the instructions and have no output from any input source. I double checked the wiring, the unit is getting power and I can hear the speakers "pop" when I turn the booster/equaalizer on. If I take the booster/equalizer out and go back to just the radio, it works fine, so the speakers (all new, and polarity correct) are working fine as well. Did I get a bad equalizer?
It seems that you have got a bad equalizer
you should better replace it if possible
Posted on Jul 12, 2008
I need a wiring schematic too hook up a equalizer to a receiver
No schematic is necessary - the audio outputs of the play station go into the audio inputs of equalizer - then connect the audio equalizer output into the audio inputs of the receiver, could be labeled aux or whatever. Then turn receiver source control to the input you used and voila, SOUND.
Nov 23, 2013 | Sony Playstation 3 (PS3) Console
Don't no how to hook it up ...
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
Wiring diagram for BOSS AVA 1209 equalizer. It was given to me dont know where the 4 wires connect red,black,white,last wire is orange or pink.
Your wiring is as follow's :
The Red wire is your (+) Positive that connect's to the power source
The Black wire is your (-) Negative that connect's to the ground
The Orange wire is your Auxillary (+) that turn's on Amplifier's or Power Ant.
You should have a Green wire, a Green wire with a White stripe,a Gray wire, and a Gray wire with White stripe
The Green wire is the LEFT channel input (+)
The Green/White wire is the LEFT channel input (-)
The Gray wire is the RIGHT channel input (+)
The Gray/White wire is the RIGHT channe (-)
PS. I have no idea where that White wire you mentioned goes.
Feb 03, 2011 | Boss AVA1209 7-Band Car Equalizer
How to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Jul 04, 2010 | Kenwood Audio Players & Recorders
How to connect my realistic 7 bands equalizer to my amps .
Since you have not mentioned the amplifier I am not aware if the amp does have an preamp input and output. In case you have these then the output of the preamp of the main amp must be connected to the input of the equaliser and the output of the equaliser must go to the input of the main amplifier. The sources can be connected to the amplifer according to the selected device.If your amp does not have the preamp input/output then connect the source to the input of the equaliser and the output of the equaliser to the aux of the main amplifier.Now set your amp's bass and treble to mid point and set yout equaliser accordingly. Hope this helps. Good day
Jun 05, 2010 | Audio Players & Recorders
The grapic display lights but there is no output
1-check your input and output cable.
2-check all your control volume and slider in proper setting.
3-confirm that input sound source is working properly.(try it without the equalizer).
4-if the cables are o.k and sound source is o.k and you still get no output you must pass it to service center.
Sep 28, 2009 | Teac EQA-220 Home Equalizer
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
take two out puts from your cd player and run them in the inputs of the equalizer and believe me they are going to work.Remember if the outputs from your CD player are of high note (out put)the volume should be kept at minimal to avoid the rumble.
Aug 18, 2008 | Pyramid 10 BAND EQ 300 W WITH LIGHTS Car...
Stereo wiring
Wire outputs from CD player into inputs of Equalizer, then connect outputs of equalizer to inputs of amp, then output of amp to speakers. Use the best wire possible for all connections, i.e. Monster cables ect.
Please post ratings for all solutions please.
Dec 04, 2007 | Washing Machines
Installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
May 26, 2007 | Pyramid PR333E Home Equalizer
Car Audio & Video Logo
171 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
