Peavey amp fan runs constantly - Audio Players & Recorders
  • 682 Answers
It is normal that ventilation fan run constantly.
Posted on Jul 02, 2008
What are the cooling fan specs for Peavey mixer amp pvi8B?
To get a replacement, Call Peavey and ask for the parts department. They normally sell things cheaper than you'd expect, and it will be the correct part.
Jun 09, 2015 | Peavey Music
I have a Peavey mk VI bass head that has stopped working. It powers up and the fan works but nothing comes out. I've checked the cabling to the speaker cab.
Unfortunatly it could be a number of different things, and without the amp in front of me, I'd be shooting in the dark I suggest taking it into a Peavey repair center. Here is a link to the service locater page-
Peavey com
Feb 25, 2015 | Peavey Music
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
I have a Peavey PV 2600 amp, when it is switched on only the fan works but nothing else. It is three or four years old and it was given to me by a friend, roughly how much would it cost to repair and get...
Either have it fixed or offer it up as broken at auction.
Estimating cost is near impossible, however labor could easily be aver $100.
The fan is controlled by a rather complex circuit depending on thermistor temp sensors. The temp sensors appear to also shutdown the amp.
If the fan comes on instantly, there MAY be a failure in this circuitry which is inexpensive parts...
Each side of the amp has 10 major power transistors and if all were blown it would add significant parts cost to the repair.
Aug 18, 2010 | Peavey Pv 2600 Power Amplifier
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Jul 09, 2010 | Peavey Audio Players & Recorders
Caused speakers to smoke:(
If it's the speaker cabinet itself that';s smoking, you have most likely burnt some components in the passive crossover. Pull it out and you may see melted parts or scorching on the circuit board. Peavy does repairs on it's own products pretty reasonably if there's no local tech. Call Peavey Customer Srervice at 877-732-8391.
Apr 30, 2009 | Audio Players & Recorders
Two amp
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
Geno
Feb 27, 2008 | Harman Kardon AVR 630 Receiver
63 people viewed this question
 Grubhead
Grubhead
