Question about Samsung Televison & Video
Disc will not play when inserted. "Cannot play disc, please check disc" warning comes up on screen. tried a few different discs, always the same warning. Is there an easy fix or am I in need of a trip to the repair shop ???
    Genius:
  • Samsung Master
  • 1,550 Answers
You need a trip to a repair shop
Posted on Jul 02, 2008
Why does computer play only one disc in 2-disc set?
Look very closely at that DVD, Richard. Look for fingerprints or scarring near the transparent center section - DVD recording always starts in the middle and progresses outward, the opposite of vinyl records.
Aug 08, 2014 | Televison & Video
Dvd player does not work
It sounds that the laser pickup unit to your disc player is either faulty or dusty. Insert a lens cleaning disc into the player, and play it for at least two times. If the fault is with dust or dirt, this must solve the problem. If not, make sure that the optical pickup unit is faulty, and should be replaced. Lens cleaning disc an be bought form most of the electronic spare part shops at your town.
Jul 20, 2012 | Broksonic TV
"No disc inserted. Please insert the
No disc inserted.
Please insert the original "FIFA 09" CD/DVD.
Jun 30, 2011 | Computers & Internet
Dvd player gives message "this
Tries many more DVD discs tries to check it out as the disc u insert in the DVD player tray have difference region format disc that why u getting that answer.
Jun 05, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
The disc in the game cube does not turn. the error say, game disc cannot be read.
The Disc could not be read:
  1. Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  2. Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting
Troubleshooting - Multiple Discs
  1. Some games may need to be cleaned. Clean each disc with a soft, slightly damp cotton cloth (use water only). Clean them from center towards the edges; do not use a circular motion. DO NOT use paper. Once they are cleaned, dry the disc using a dry portion of the cloth and wiping in the same style as you did to clean the discs. After all of the water is gone, let the discs sit for at least two minutes to completely dry before inserting any of them into the Nintendo GameCube.
  2. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  3. Ensure the games are being loaded properly. With the power turned off on the system, replace a Game Disc (printed side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen. Try this with a few of your games.
If Troubleshooting doesn't fix the problem, and it is happening with all your games, then your system will need repair. Check out our convenient repair options.
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory
Nov 28, 2010 | Nintendo GameCube Console
Im trying to play Wii Fit Plus, but every time I put the disc in i get this message: "The Game Disc could not be read. Refer to the Wii Operations Manual for details." I've tired cleaning the...
Have you tried inserting other game discs? like 3 types of disc. If your Wii console plays those discs and don't play with the game disc that you wanted to play, then the format of that disc is not recognized by console. Some disc formats are sometimes incompatible with the player console.
Nov 04, 2010 | Nintendo Wii Console
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
147 people viewed this question
Henry  Thomas
Henry Thomas
