Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
XL-2100U Bought the replacement lamp block. Supposed to be easy to install. Can't find instructions to install new one anywhere on internet. Started to take back off TV seemed I was going at it with no information.
  • 51 Answers
Fisrt remove the front cover assembly, if you go to the back of the set on the sides you will see one plastic knob on each side ,you have to loose those..then you have to pull out the whole piece from side to side(if never done it may sound like if its braking) there are three clips holding itl,once its out you will see the lamp cover on the center part, one plastic knob also,once removed you will see the back of the lamp. reverse the process in you will be fine.
Posted on Jul 03, 2008
Red light blinks 4 times
Hi,If your tv is close to 6000-8000 hrs or 2-4 yrs and haven't replaced the lamp yet, it might be time.The part # is XL-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm and here's the instructions to replace it: http://www.fixyourdlp.com/guides/sony/XL-2100U.php
Mar 22, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
Feb 23, 2008 | Sony XL-2100U Projector Lamp for...
Black screen with sound on xbr grand wega 70 inch
Hi,If tv is between 6000-8000 hrs 2-4 yrs and havent replaced the lamp it might be time to do it so.Here's your part # XL-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm here's instructions to replace it : http://www.fixyourdlp.com/guides/sony/XL-2100U.php Thank you and have a blessed one!
The red lamp light is flashing on our Sony KDF42WE655. What is the replacement parts I need to fix and instructions for doing so. Thanks.
You can find the documentation for your Sony on the Sony Documents & Downloads page.
The part is Sony XL-2100 or XL-2100U. Instructions are in the manual, page 16.
Feb 05, 2010 | Sony XL-2100U Projector Lamp for...
Xl-2100u
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your Projector from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    Help for Sony XL-2100U Projector lamp
    If you need XL-2100U Lamp for your Sony Grand Wega, its available on Sony Accessories and its price is approx $200
    Here is bit details of required part from Sony web site...
    Part Number is ... A1606034B LAMP BLOCK XL-2100U
    Compatible Models
  • KDF-42WE655
  • KDF-50WE655
  • KDF-60XBR950
  • KDF-70XBR950
  • KF-42WE610
  • KF-50WE610
  • KF-60WE610
  • Need further help, let me know.
    Sep 20, 2008 | Sony XL-2100U Projector Lamp for...
    XL-2100U lamp cycles on and off
    Hi
    I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
    Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
    Replace lamp on sony kf42we610
    If you need new lamp for replacement, its part number is A1606034B* LAMP BLOCK XL-2100U
    its price is $200 and available at Sony Accessories (please enter tv model number in search box to get result).
    Bye
    Sep 08, 2008 | Televison & Video
    Replacement Instructions
    Hi
    it's a simple switch out, first make sure your set is unplugged, open the panel concealing the lamp, unscrew the door, unscrew the lamp, pull it out straight towards you it is attached like an outlet plug, carefully switch it with the new one be sure not to touch the lens, screw in tightly replace the compartment door then the panel and your done....good luck }:)
    Jul 04, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
    Sorry did not know if I posted this correctly or not.
    I just brought my kf-42we610 sony authorized service-tv went black would not turn on-I was infromed Sony knows about problem with the fan in back -gets way to hot and basically melts everything-they are fixing free of charge until march of 09
    Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
    59 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
