Question about HP Photosmart 945 Digital Camera
Hp 945 frosen with red light on
Taking pictures the camera frosen lens out en red light on and the LCD is lihten up. I tride every thing and it stil dont work.
  • 2 more comments
  • Anonymous Jul 02, 2008
    My camera locked up the same way. I contacted HP service but found they were no help. They said they do not repair the cameras but offered to send me a coupon to buy another HP camera. The coupon was worthless as I could buy the same camera elsewhere for less. I'm pissed and will not buy another HP product ever again. This was $399 down the drain. HP SUCKS!
  • dawienagel Jul 03, 2008
    The camera are stil not working
  • Anonymous Jul 15, 2008
    My HP 945 locked up the same way. I have already tried everything they are suggesting and it still will not work.
  • Anonymous Jul 16, 2008
    Same problem - view screen flashing and red eye light flashing at same time. Contacted HP and they tried to sell me a lower end unit. Camera also drains out a new set of batteries overnight. Tried taking batteries and memory card out of camera for over a day and put back in to have same problem.
I posted on July 16 with this flashing problem and played around and got mine working again.
Originally I would charge through the docking port. What I did was pull the charged rechargable batteries out of the camera and took the charging cable from the docking station and pluged it directly into the port on the side of the camera. The camera started working again. Then while the charging cable was pluged into the camera, I reinstalled the rechargable batteries. After installing the batteries I unpluged the charging cable and the camera still works. I have shot and downloaded from the camera pictures with no more problems. Use the docking for downloading pictures and the side port on the camera for recharging the batteries.
I do not know if this has anything to do with the original problem but I did not have any problems with this camera until I placed it on the docking station with non-rechargible batteries.
Hope this helps.
Posted on Jul 21, 2008
My fujifilm finepix f60fd dropped one night and i tried to fix the lens. But now it wont allow me to take any pictures and is saying '' zoom error''. it does allow me to veiw my pictures.
Does it turn on at all, can you see things through the viewfinder or back screen (LCD) ?
My guess is when it fell, the lens got pushed in or to one side and it is now dented or bent and its getting stuck or hung up.I know that with my little canon if my finger is even touching the lens when it is trying to turn on, the camera wont work and i get a "Lens ERROR" code. My guess it is a safety feature so you dont burn out the tiny motor in the les system. youd either need to send it out for repair or ues this as a perfect excuse to up grade to a newer camera. One more thing, when turning the cam on, can you pull the lens out physically?
Jul 08, 2011 | Cameras
There is no image when it is in camera mode but can playback pictures taken before the problem occured. when i take pictures no image in the lcd monitor and no picture taken when i check in playback
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Now the A460 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Sep 24, 2009 | Canon PowerShot A460 Digital Camera
Cannot see anything in the sd750 LCD
flexible pcb is broken or sutter unit is stuck
Aug 22, 2009 | Cameras
Camera lens go in and out about 3 times, I cant take pictures.
1. Remove the battery and reinsert it after 30 seconds. 2. Try resetting the Camera. To reset, refer supplied Manual. 3. If stil not resolved, please get the device serviced.
Aug 06, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
Red lights on focusing screen very faint
It sounds as if you must have had the lens off to get the focussing screen dirty. If not, it could be that you have dirt on the eyepiece you look through. The best thing for that is a soft brush to whisk away any dust on the eyepiece. you mention at the end of the question you need information on how to replace the focussing lens. It sounds as if you are not sure which bit of the camera is which, as the focussing lens is the one on the front of the camera where the light for the picture comes into the camera, and has rings around it which you turn and focus the picture while you look through the viewfinder at the back of the camera. If it is mucky, you need to blow the dust off the front of the camera lens with a blower brush, or a soft brush, or blow through a drinking straw onto the lens to clean as much off as you can. Don't try to clean it with a heavy hand, as it needs to be cleaned as carefully as possible, or any scratches will make the picture less good than it should be. My best advice is to take it to a camera shop and ask their advice, but first read up a book on basic photography and see how to look after a camera, and make sure you know basically how it works. You may find the shop will want to take it in for servicing, but first I feel you need to learn more about cameras. If you actually mean the screen, then I would definately take it to a camera shop to have them replace the screen with a new one - it needs you to understand the camera well though before you start, or you can ruin the screen quite easily, as they are delicate and fine items.
good luck with your photos!
Aug 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Camera Turns off and flashes light soon after turning on then freezes
I have exactly the same problem and I found, that it is probably related to rechargable batteries. If I use normal batteries, everything works fine. Confusing is, that I used to use rechargable ones all the time, but errors started few days ago. I also have two sets of rechargable batteries, but both are useless now. Maybe that camera is getting old and it needs fresh 4x1,5V from normal batteries instead of 4x1,2V from rechargable ones.
Oct 01, 2006 | Olympus Camedia C-725 Digital Camera
HP Photosmart 945 Digital Camera Logo
159 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
