Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd-52525 no image
Hi i have the lamp indicator in red and no image?
  • Jane Doe Jul 07, 2008
    Same here, ordered lamp so will see if this works.
  • Mitsubishi Master
  • 8,617 Answers
Have you replaced the lamp? If so and it still lights up as red you need the V26 DLP PWB PCB kit to replace the defective capacitors on the PWB the kit has all the capacitors and instructions on CD
Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 04, 2008
I have a Mitsubishi digital WD-52525, and the "lamp" indicator is illuminated in red. Can I buy a new lamp and replace it myself?
If you have a red led solid. check the fans and make sure they work. Sceond push both input and menu and see what the blink code is?
Jul 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My Mitsu 52525 lamp indicator went solid red. I
sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
May 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hello, I have a 52525 and the lamp indicator went
push the menu and device buttons on the front of the set both in together and hold for 6 seconds and see what two digit error codes blinks. It will most likely blink a 3 pause then 4 and then repeat the sequence indicating a 34 error for lamp abnormality which is almost always caused by faile capacitors on the Power pwb.
Jan 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My wd-52525 lamp indicator indicated that I needed a new lamp. I purchased a lamp, installed it and of course it still indicates a bad lamp. I took the lamp assembly and had it checked out by a tech and it...
Actually Tim, it seems more like a ballast issue, I recommend you replace it, since ity doesn't have enough energy to keep up with the lamp, and that's why you gte a lack of image.
Aug 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
