Question about HP Compaq Presario V2000 Notebook
Compaq v2000 have had many problems after replacement motherboard for compaq v2000. -now fully charged battery goes flat over few hours when the laptop is switched off.- come to switch back on and nothing,-have to plug back into mains. Have 3 good batteries and same with each one
  • 159 Answers
You would have to pull down the laptop if you can. there seem to be something shorting out the 14.v battery connection allowing it to discharge the charge from the battery when off. if you can get the motherboard exchanged for a new one thats you first go, because the problem is def the motherboard.
Posted on Jul 02, 2008
How long for new battery to charge full
maybe 6-8 hours. for sure overnight. If it does not charge fully in 12 hours, there is a problem. It might be the connection between the charger and motherboard if the laptop is old
Feb 10, 2015 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Why does my compaq presario v2000 battery always drain even while plugged in?
If the battery fully charges and lasts in normal use without the charger plugged into the laptop, then this clearly indicates a problem with the charge circuits in the computer, unfortunately this is built into the motherboard.
Mar 06, 2012 | Compaq Computers & Internet
I hav charging problem wit my hp laptop
I'll need to know more information if I'm to diagnose your problem, but I think your battery may have been exhausted. Rechargeable batteries, including laptop batteries, have a limited lifespan and, after many charge/discharge cycles, cease to be able to hold a charge.
If this is the case, you should replace your battery, and conduct normal battery conditioning- charge the battery up fully, then remove the power cable and allow the laptop to drain the battery. When the laptop goes into hibernation mode, leave it for a few hours until the battery is completely drained. Then, plug the laptop in again and allow it to charge up fully. This process should be repeated monthly in order to ensure a long battery life.
Mar 13, 2011 | Computers & Internet
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
How long does it take to charge the battery to a full charge...thanks,judy....on a presario V2000
usually 8 hours is what is suggested when you get a new battery. i like to burn down the power on the battery completely till it turns the unit off, then let charge for 24 hours just to reset the battery correctly.
Jul 19, 2009 | HP Compaq Presario V2000 Notebook
Problem
DC-DC board or motherboard. does it boot up from a charged battery (like from another laptop)?
if it works on battery power then i'd look to replace the DC-DC board (its a little board inside the laptop that holds the power jack and a few power-related components)
if it continues to beep even when only on a battery then you should look into a replacement motherboard. and if you have a Compaq V2000, i'd look into a "parts/repair" laptop from eBay or something because that will cost less then just a motherboard.
also the DC-DC board may be built into the motherboard. in that case there is none and the motherboard is the thing you want to replace.
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
Battery not charging...but is recognized by V2000
My guess since the battery checked fine in another laptop would indeed be the charging board or charging circuit on the motherboard.
Jun 14, 2008 | HP Compaq Presario V2000 Notebook
hi.. unfortunately i've seen many cases like this and it looks as if from what you are describing that your laptop is fried if there is no boot up at all.. how old is you laptop and what brand is it?
Feb 19, 2008 | HP Compaq Presario V2000 Notebook
Sudden Shutdown
bad capsisters on motherboard thx nick
Feb 10, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
