Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Model # R52WH74
RCA R52WH74 turns on great picture but after be on for 45mins. it will go to a black screen with sound.
  • losdollars Jul 04, 2008
    screen goes black after 45mins with sound
  • Anonymous Jul 12, 2008
    I have the same problem after about 10 minutes my tv will just stop working no sound and no picture.
    New Friend:
My tv screen is black, and light green is on and is off, and is on and is off
Posted on Dec 01, 2012
  • RCA Master
  • 5,138 Answers
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Posted on Sep 17, 2008
I have a rca Model R52WH74 which the picture resolution is given out. Please tell me what can I do to fix this issue? It look like the picture is in 3D
Jun 25, 2010 | Televison & Video
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Locating the ''flyback transformer '' on a rca mod #R52WH74
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
Mar 10, 2009 | RCA Televison & Video
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
467 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
