Question about Olympus Camedia C-150 Digital Camera
Write protection The camera shows 'write protect' on the screen and the instruction manual says to reset using a computer but doesn't say how. Anyone know the answer.
  • mehkigandhi Jul 23, 2008
    i m also having same kind problem.I tried formating with normal card reader of computer then card will work till we shut off the lens cover. Immediately after second time opening the cover same problem " Write Protect" comes.
    FYI, I didn't tried with new card.
    Kindly guide what could be the solution.
    Genius:
  • 1,036 Answers
Hi, The PDF of your manual is HERE. Page 28 refers how to remove protection on stored photo's.
Page 30 lists how to connect to your PC with USB cable.
You should use the software disc with the camera (or available from Olympus) to navigate to delete this option.
It should be on a menu as an option.
If you still have problems, Send olympus customer support an Email with your problem. - Their link is here -
http://www.olympus.co.uk/customersupport.htm
Posted on Jul 04, 2008
  • Richard Perkins
    Richard Perkins Jul 04, 2008
    If it is an SD card - there may be an actual switch on the card.
    Remove the card and flip it.
    Hope this works for you.
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How can I reset the protect disc
The PROTECT function is used to prevent any valuable images that you have recorded from being erased accidently. These images will appear on the images with the protect indicator (key symbol).
To release the PROTECT from the images, set the PLAY/STILL/MOVIE selector to PLAY, then display the images to be released.
Select FILE , PROTECT and then set it to OFF. You can do the same in Index mode to delete multiple selected images. To release protect from all the images, select index screen and select ALL, the select to OFF.
You can view the instructions on page # 74 of the manual.
Thanks for contacting FixYa.
May 09, 2011 | Sony Mavica MVC-FD200 Digital Camera
On my DMC-TZ8 the screen says "this memory card is write -protected " how do I solve this problem , only had camera two months I have took memory card out all seems alright THANKYOU
Your memory card is either write protected or corrupted.
  • If it's write protected, it can be very easily fixed.
  1. Turn off cam.
  2. Take out the mem. card. (it's probably located near the battery. press down on it and release it. Then it will pop out.)
  3. Slide the small switch on the side of the card to the position marked with an unlocked padlock.
  4. Put card back in and turn on cam.
  • If that doesn't seem to be the problem, then it's likely that the memory card is corrupted. This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera. You might not be able to access any pictures that were stored on your cam, but you can try using a data recovery software like Recuva if you want to recover pictures ( click name to download ). If you want to use the card again, You can try formatting it (differs from cam to cam, check instructions manual for specific instructions) If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
That's it. hope that helped.
May 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Write protect
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom of your computer screen?
Oct 28, 2009 | Olympus FE-210 Digital Camera
Write protect error olympus c 150 (cant get rid of read only)
Hi!
You might wanna check on your memory card. It could be that it is currently on write-protected mode. What you want to do is to check it now and then look for something like a push button. If its on the top position, push it downwards. Vice versa.
Aug 29, 2009 | Olympus Camedia C-150 Digital Camera
Olympus 850sw- write protect and picture error
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Dec 29, 2008 | Olympus Stylus 850SW Digital Camera
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
How to unlock the memory card of my digimax S500/S600
Your card is protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 24, 2008 | Samsung Digimax S500 Digital Camera
Need an urgent solution regarding "Protection" problem (I have a program to record in next 2 hours) pls pls help !!!
have suddenly getting a "Protection" message in Camera mode. - The viewfinder is OK and i can see the view but a "Protection!" message is blinking in the middle of the screen and the record button is not working if i press
Apr 13, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Olympus Camedia C-150 Digital Camera Logo
378 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
