Question about Lands Phones
Static No, not electronics. The store where items were purchased does not carry parts to this unit. Will have to contact Uniden directly for replacement parts. Thanks for trying any way...
  • corky742 Jul 02, 2008
    Thanks for the suggestion, but it would probably be just as expensive to purchase a new unit.
    FYI, came home from work today and the phone still had the icon but no static in the unit.
    Go figure.......
    President:
  • 2,712 Answers
Yes, you can try, although I am not sure if they ship out certain parts to individuals. Have to cornered the problem, and found the faulty part? If not you may want to swap out the entire PCB in the handset. Not sure if Uniden supplies these boards to non service center entities, though..
Posted on Jul 02, 2008
Um525 service manual
Unfortunately, in my experience Uniden will not part with their service manuals cheaply. Perhaps if you contact them directly you may be able to get some joy.
Link to owners manual is posted at the link below, with contact info on the last page
-Steve
http://www.uniden.com/pdf/UM525om.pdf
Jan 18, 2014 | Uniden UM525 ES Series VHF Radio with...
Tip
I see it has been suggested to perform replacement of the control board if the...
If you have a dehumidifier that is not producing any water then you are wondering what you need to do to get this thing to work for you. In some cases you may be able to do something and in other situations there may be nothing that you can do.
If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
A few things that can cause this are:
The circuit board relay has gone bad…replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
The compressor has failed…if you hear a buzz for a few seconds, every few minutes, then you have a bad compressor or at least bad start components on the compressor. Either way it again is a costly repair.
If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
Also if nothing is running check the float switch or the bucket switch. Many of these switches are very touchy and if you do not have the bucket in place just exactly right it will not trip the switch to allow the unit to run. These switches often are more fragile then they should be and break easily. The good thing is that when available they are easy to replace and relatively inexpensive.
There are some parts available for a few brands, but with the prices for most of the parts that you can replace running anywhere from 40.00 – 80.00 dollars, replacement parts with labor to install them, makes a repair more then the few hundred dollar cost of many of these dehumidifiers.
As you can see there are quite a few things that can cause your dehumidifier not to work. Systematically go through the list and eliminate things to get to the bottom of the issue causing your problem and then decide if it is worth spending the money to try to fix the old unit. Only you can make that decision.
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
on Aug 18, 2011 | Dehumidifiers
The swivel joint on my quinny buzz has just broke, were can i get the replacement part
Hi
Do you mean the front wheel unit?
If your Buzz is under 2 years old please contact your retailer with proof of purchase for a replacement to be ordered under warranty terms and conditions.
If it is over 2 years old or you do not have a proof of purchase but you are in the UK you can order via your local Quinny retailer or direct with customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to purchase the item.
If you're not in the UK please visit www.quinny.com and select the country you're in, then use the "Contact Us" tab on the right side of the screen for your enquiry to be sent through to the customer care team in your country who can assist with spare parts required.
Jan 30, 2012 | Quinny Buzz 3 Travel System Phantom...
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    I've recently bought a new Nintendo 64 (used but in a perfect condition), but I got the SCART cable with it instead of the RCA-cable. I connected it to my Samsung LED's SCART port and then when I...
    Replacement Parts (AC Adapters, etc.)
    Important Note: Before replacing any component, we recommend trying our troubleshooting information. Select a system from our customer service main page and you will be able to find troubleshooting tips to assist you.
    There are several ways to get replacement components for your Nintendo system, including AC Adapters, controllers, and installation cables:
    Purchasing From Nintendo's Online Store
    Nintendo's Online Store is an excellent place to buy replacement parts for your systems. The store currently accepts Visa and MasterCard (or you can print out your order and send it in by mail with a check or money order), has a convenient real-time checkout basket, and offers secure online ordering. To find out more, please visit our store at http://store.nintendo.com.
    Not sure what the part you want is called, or can't find it?
    Nintendo's Online Store features an interactive Part Finder for all our systems. Simply select the system you need the part for, and place your cursor over the name of the part pictured to learn more about it. Click on the part's name to begin the purchasing process.
    Purchasing From a Retailer
    Many retail stores that carry Nintendo products also carry replacement components, Player's Guides, and more. You may want to call first to be sure they carry the item you are looking for. To ensure compatibility, make sure that the item you are purchasing is licensed by Nintendo. For a list of some online retailers that carry Nintendo products, visit our online retailers page.
    Purchasing Over the Phone
    Nintendo of America Inc. offers convenient phone orders using a Visa or MasterCard. For assistance, please call Nintendo's Customer Service Hotline at 1-800-255-3700 between the hours of 6 a.m. and 7 p.m. Pacific Time, 7 days a week.
    Other Countries:
    If you live outside the U.S. and Canada and wish to order a replacement part, check with the local distributor for your country to see if they offer the item you are looking for.
    Was this information helpful?
    Aug 06, 2011 | Nintendo 64 Console
    Lost the AC Adapter to plug in my Insignia I-PD720 DVD Player
    Our parts supplier lists the AC adapter as unavailable, but an alternative may be available. I would recommend calling them at 1-888-237-8289 or carrying the unit in to the place of purchase or an electronic parts store to pursue an alternative.
    Mar 05, 2010 | Insignia I-PD720 Portable DVD Player
    I have the Uniden DSS7955 + 2 - it it on the same line as my broadband computer line and am getting constant static. When I disconnect the broadband line, the static disappears. I had an older model Uniden...
    You will need to get a DSL filter to separate the DSL(broadband) from the talk line. These can be purchased at any store that supports computers.
    Apr 16, 2009 | Lands Phones
    No power to DVD portable unit
    If you purchased an extended service plan from Best Buy, then it's not voided just because they don't carry the product any more. Mobile electronics change yearly; almost nothing that was sold two years ago is still available. If your local store won't help you, contact the corporate offices at 1-888-Best Buy. They may not be able to replace the unit with the same model, but they are legally responsible for either repairing it or replacing it with something comparable.
    May 27, 2007 | Directed OHD900 Car DVD Player
    Lands Phones Logo
    62 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
