I have a Samsung Pleomax External Hard drive 4 GB. I all of sudden stop working. It flashes a Green and Amber light on the top but no computer will read it. Any suggestions.
    Scholar:
  • 174 Answers
Green is steady or ready and amber light is activity remove the usb cable and plug it again
Posted on Jul 02, 2008
My Pleomax external hard drive stopped working on my MacBook (OS Maverick). It worked for one day and that was it. It flashes green and red when connected.
Probably not an issue with the MacBook but with the Pleomax drive. Be sure the drive is getting enough power to begin with. If it came with a 2 headed USB cable be sure to connect BOTH USB connectors to the Mac. You may also want to try the drive while your COMPUTER is plugged in and charging. Laptops and external drives don't always get along due to power differences and specifically laptops who do not want to waste their battery power on an external drive. If all else fails, try the drive on another computer just to make sure it is a drive problem and then contact the manufacturer for a repalcement drive.
Dec 11, 2013 | Samsung Pleomax 120GB External - USB 2.0,...
Samsung Pleomax Ultra-Portable UHD-12G - hard drive - 12 GB - Hi-Speed USB. I think the autorun was deleted off of this flash drive. The computer does not see it at all. There are no yellow x's under...
This could be an issue with assign the drive a letter:
1. Right Click on "My Computer" (might be called computer)
2. Left click on Manage
3. On the left click on "Disk Managment"
4. Check to see if the 12GB USB drive is showing up there if it is then right click on it and assign it a drive letter.
If the USB does not show up in "Drive Management" then try another USB port or another computer to test to see if the USB drive shows up.
Hope this helps
Mar 07, 2011 | Samsung Pleomax Zirex UHD-12G 12 GB USB...
Samsung Pleomax 12 GB hard drive, computer says "USB Device Not Recognized"
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | Samsung Pleomax Zirex UHD-12G 12 GB USB...
I have a maxtor 5000LE the device shows under
Could be that the control board inside the device is going bad. Have you tried other cables to connect to your computer?
If that fails, then I'd suggest removing the drive from it's enclosure and using an adapter to connect the drive directly to your PC as an external device. I found one on eBay, years ago, for about $13USD.
Oct 25, 2017 | Maxtor Personal Storage 5000XT (S01J250)...
Flashing power light.
Have you tried a differnt usb cable if that dos not do it get back with me and I will walk you though checking it out
Jan 09, 2010 | Computers & Internet
Samsung SSCDVR not recognizing Hard drive.
your reformatting the hard drive removed everything
it is now not booting from the hard drive because there is no operating system to boot from
you will have to put the os disc into an external cd drive , change the boot priority from hard drive to cd and get the os onto the hard drive
May 10, 2017 | Samsung SSC DVR Digital Video Recorder...
Pleomax problem
Try clicking on the icon in the taskbar and if it's like SanDisk flash drives there is a program you need to install from the Pleomax itself, that enables it and several tools as well. When you see that window, there will more than likely be an eject button as well.
Mar 16, 2008 | Samsung Pleomax Zirex UHD-8G USB Hard...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
