Question about ASUS P5VDC-MX Motherboard
Audio Hardware Detection
I have installed Windows XP SP 3 after which my audio hardware is not being detected. The motherboard CD installs the Realtek audio drivers and codecs but is not working becoz the hardware is not present.
The system hardware info shows that the PCI driver is not installed
Motherboard - ASUS P5GC-MX
  • ASUS Master
  • 13,433 Answers
Check the website for newest drivers if not you have to reinstall then install sp3 and hope your drivers work again. or just stick with sp2.
Posted on Jul 02, 2008
When i instlln dg31 pr by intel motherboard cd ..all driver istalled but the audio driver failed to install what should i do
go to hardware device manager and remove audio driver then refresh update new hardware and locate where the cd driver inserted. and restart pc.
Mar 01, 2011 | Intel DG31PR Motherboard
Intel E5200 Dual Core 2.50gHz 500GB Sata HDD 2GB RAM Asus Extreme AX700 graphics card 256MB Windows XP Pro SP3 After a fresh installation of Windows and loading of all the drivers in the Disc supplied,...
Go to devise mgr and look at the sound hardware under sound, rt click on realtek and click on properties, look at driver, does it say windows or realtek,and check version and date,then go to realtek
and see if the driver is the newest and the right one for your hardware.
That was great that you listed some info,but the wrong info,ex for OS, you should have listed the motherboard model #, you should post back the model# and what it said under driver,version,date of driver. Then someone can check to see if the correct driver is installed.
Mar 21, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
No Sound After Reinstall
Have you Reset you BIOS,because after you build a machine up,the Bios has to be set to Default,and were you grounded with a arm band when you put the parts together?,During the assembly it is paramount that you wear a grounded arm band so that your body electrical discharge does not interfere with the components,you probably have a hardware/software conflict.some thing in the BIOS is most likely left on.or set to hardware.
Dec 14, 2008 | Biostar P4M890-M7 Motherboard
ECS P4M900T-M2 Motherboard windows xp service pack 3 audio driver
are you all running vista or xp ? if xp this sound chip will only work with sp1 installed as it is designed for vista
Nov 07, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
Audio of my pc
The best way is to fix it to tipe a name on google + free downloading hardware or to be secure you need to pay small amount of money for Driver detective I have fixed all my drivers for nothing.
Be carefully what to download instead from google.
Nov 04, 2008 | Microsoft Windows XP Professional With...
Realtek HDA driver
The driver you are installing needs more requirements. try to install driver from mother board CD. If not try to download realtek HD driver compatible to your processor.
Aug 28, 2008 | Microsoft Windows XP Home Edition
ASUS motherboard
Hi fernandito
(01) It'd be best to check for updated drivers rather than attempt to install the ones off of the CD. Drivers that we receive w/ our hardware purchases are quite often out-dated. It's always a good idea to check w/ the manufacturer online and get the latest drivers there to install.
(02) ASUSTeK lists the P4S800D audio drivers as "SoundMAX". It doesn't list "RealTEK" audio drivers for any of the (3) variations of this motherboard.
(03) What precipitated your needing to install the drivers?
(A) You're having issues w/ one or more integrated hardware device (e.g. Your audio)
(B) The motherboard is new to this system build - this is the 1st drivers installation
(C) Other: Please, explain
(04) Is this a new (clean) Windows XP build ?
(05) Is this a case of a new motherboard on an old Windows XP build?
(06) If this is not a new (OS) build and the motherboard is not new to the system, did the integrated audio work properly b4?
(07) If the answer to (06) is YES, what precipitated or coincided w/ the onset of the issue you are experiencing w/ the integrated audio or any other issue you're attempting to address now?
(08) Are you experiencing ANY other issues at all w/ this system? If so, please, explain
(09) Have you ANY other related information at all regarding this issue?
RECOMMENDATION ACTION TO TAKE:
(10) There are (3) models of your motherboard listed on ASUSTeK
(A) P4S800D
(B) P4S800D-E Deluxe
(C) P4S800D-X
(11) Please, go HERE and (in the upper left of the page) enter in the "Input Model to Search" field the model number of your motherboard
(12) Click the drop down arrow in the "Select Category" field and choose "Drivers"
(13) The resulting page will show the (3) variations of this motherboard model.
(14) Click on the appropriate one.
(15) You'll be taken, then, to a page where you will find BIOS updates, drivers, utilities and documentation for your motherboard.
(16) Click on the DRIVERS tab
(17) Download the appropriate drivers for your operating system.
(18) Every version of this motherboard model lists SoundMAX audio drivers. None lists RealTEK.
(19) How are you identifying your motherboard model number?
(A) Off of the box that it came in?
(B) Using a PC hardware audit utility?
(C) Physical inspection of the board?
(20) It's quite possible that the CD you have is not the correct one for your motherboard or that you've miss-identified your motherboard.
(21) To be sure you have identified the correct motherboard model number, please, download and run "Belarc Advisor". You can find it HERE. Belarc Advisor is a free pc hardware and software audit utility.
(22) Once you've confirmed that the motherboard model no. has been correctly identified as one of the P4S800D models, perform a "Clean Boot" and attempt to install the audio drivers you downloaded from ASUSTeK. (**1st, the old audio drivers via Device Manager (if applicable) that you downloaded from ASUSTeK.
(23) For the steps for performing a "Clean Boot", please go HERE.
Please, post back here w/ the results and/or any questions, comments, observations you have.
Thank you,
BJ @:)
Apr 14, 2008 | ASUS P4S800D-X Motherboard
Audio driver problem
You should install the Chips drivers or intall all the driver in series listed in your CD Utilities. Its good if you download the latest drivers of your system at www.asus.com or here: http://support.asus.com/download/download.aspx?SLanguage=en-us
You should download for 64x2 drivers.
Jan 07, 2008 | ASUS M2N-MX Motherboard
Sound
Do you have a sound card in your pc? If you do have you got the drivers installed?
Aug 30, 2007 | Microsoft Windows XP Professional With...
ASUS P5VDC-MX Motherboard Logo
291 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
