SOURCE: Furnace doesn't reach desired temperature
On the thermostat if its a manual on then pop the cover off and look for a small dial with numbers on it. Take and move it tpoi a higher number than whats it is set at. Its called a heat anticipater and is supppose to make it so that the unit does not oveshoot or under shoot like what your experiencing. If its a digital oine then you are going to have to configure the setting in the insdtallers menu.
SOURCE: Air conditioner shuts off early.
Hi, thermostats is not problem , it's asking for cooling when it should, it's your condensing unit outside, if mechanics said, system is o/k. then it's location of condensing unit, check location of your condensing unit, in relation to direct sunlight, condensing unit best location is always a cool place, preferable away from direct sunlight, check to see, when unit is doing that, if it's expose to direct sunlight, that could be your problem, direct sunlight for long periods could cause the high pressure & temp. controls malfunction. or maybe system is not fully charge with freon, double check freon charge. if direct sunlight is your problem, build a shade or change location of condensing unit, good luck.
SOURCE: Why does the heating element in my gas furnace
The furnace has many safety controls monitoring many parameters. The most like cause of your complaint may be low air flow. The most simple reason would be dirty or too restrictive of an air filter. If the filter is clean that is about as far as you can go without a general knowledge of how that whole system works together.
SOURCE: When out temp is below 50, heater does not produce enough heat
Sounds to me like the thermostat or thermostat wires are wrong.
If you open the t-stat make sure no bare wires are touching one another.
Typical wire codes/colors are red to R,green to G,yellow to Y,w to white or w1,orange to O,blue to common(C),brow to E.
These should be the same in the air handler as well as the outside condensing unit.
Some installer may use different colors for some other reason.
Verify these colors throughout and report back.
Has the problem existed for the 2.5 years or is it recent?
Rudd compressors are warranted for ten years number one. Can you give a little more detail.
