Question about Toshiba (PA3212U) Wireless Adapter
Wireless access hi i have a toshiba laptop that my wireless connection quick working i tried a usb wire less adapter and i can connect .If i put in a wreless card in the slot in the side it will not connect i would like to repair this so as not to tie up my usb port
My wireless card was working great, then stopped all of a sudden. If I connect to the Modem directly it works, do I need a new wireless card?
Posted on Feb 07, 2010
Acer 5100 will not connect to wireless
Things to Check:
1. Please check if the wireless switch on your laptop is ON?
2. Are you able to see your wireless network in the list of connections?
If the answer for both of the above is yes, then Turn OFF & Turn ON the Modem/Router.
Please delete all the connections that are stored on your laptop's wireless settings/Wireless connections and retry connecting to your network.
On your modem/router, please remove any security passwords and make the network accessible by any one any try connecting to the network.If the connection is successful, then reprogram the modem / router with a password.
Another easy fix to find if the fault is actually with your laptop is to go to a free public wireless hotspot and see if your laptop connects to their network.If it dd, its not your Laptop but your wireless modem/router.
Feb 28, 2014 | Acer Aspire 5100 Notebook
Wireless adapter on toshiba laptop just stops working
On some laptops you can access the wireless adapter quite easily. perhaps it's only a bad connection, requiring some Electronic Contact Cleaner, or loose connection. Or the antenna, usually located behind the monitor, has a pinched , broken wire. The wire feeds through the hinges. Or , as you most likely suspect, the wireless adapter may be bad. I don't know the model of Toshiba. Take a look at this: http://www.youtube.com/watch?v=z19kc5fERsE
Dec 30, 2012 | Computers & Internet
I hav a Dell inspiron 15 laptop and i have taken wired internet connection. but somehow my lancard has stop working and i am not able to access internet. can you please tell me some alternative to lan...
you can do a quick troubleshooting on the laptop.
1. used another network cable and check that no pins are broken on the laptop.
2. go to device manager and remove the network adapter and reinstall it.
if this don't work. if you have a wireless router, you can connect to the internet over the wireless network adapter on the laptop.
good luck!!
Aug 31, 2011 | Dell Ethernet Card Network Adapter
My toshiba laptop with a realtek rtl8187b wireless 802.11b/g usb 2.0 network adapter, is connected to a wifi network with internet, but periodically the connection is lost (connected and automatically...
This is not a problem. Wireless connections sometimes tend to be inconsistent. Try closing the distance between your laptop and the wireless network adapter.
Mar 17, 2011 | Toshiba Realtek RTL8187B Wireless...
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
I have a Toshiba lap top A 105. I have lost my internet
It is possible to disable the wireless connection with the keyboard. Try the combination of Fn and F8 buttons (this is a common Toshiba shortcut) to turn it back on. If that doesn't work, look at your Network Connections (through the Control Panel, assuming a Windows OS, if needed). Check the settings and if it is enabled. In the device manager, check if the wireless adapter has an exclamation point in a yellow triangle. If you have the exclamation point try letting Windows repair the driver. (You may need to access the Toshiba website for the correct driver. Either use a different machine and put the driver on a disc or USB driver or your machine's wired connection.) If that tells you it has no problems, remove the wireless connection (and uninstall the driver) and reboot the computer and it should see new hardware and start reinstalling the driver. Then you can try to establish a new wireless connection.
If the above solutions do not help, it's likely to be a hardware failure. You could get a new wireless adapter (USB or an appropriate card for your laptop add-on card slot), use the wired network (if that has worked), or consider a new machine.
Nov 15, 2009 | Toshiba Satellite A105 Notebook
Toshiba Laptop builtin wireless modem can't find any network
If the laptop is 3 years old then it probably requires a chipset update. Goto intel's website and use the driver update utility. If this does not work then your wireless connection may be broken. You can buy a wifi USB card for less than £10 if you shop around. Good luck
Jul 23, 2009 | Computers & Internet
Toshiba pa3064u-1pcc macintosh
You have to turn on sharing on both computers first, assuming the Toshiba allows it. Your Mac does. Then you can connect it using ethernet or USB. Unless they are both connected to a network, sharing is the only way to go or if it will even work.
Aug 25, 2008 | Toshiba (PA3064U-1PCC) 802.11b Wireless...
WIRELESS SETUP CONNECTION FOR TOSHIBA TE2100
Go to the control panel. Open wireless connection wizard and configure it by giving the proxy setting of the router. There must be a DNS server to get you connected with the Domain.
First your os xp or vista
if u xp means go to network connection and see that tab, wireless network wizard and click next to open to next to next and click finish. It will appear in network connection windows. But u want to take airtel broad band wireless net key, and u open the tab if u finish ur network wizard tab. And it will open the icon it ask for key, u give it key to continue. It will ready to access the network, so this is the way
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 30, 2008 | Toshiba TE2100 Notebook
Toshiba (PA3212U) Wireless Adapter Logo
194 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
